just thought this thread would go ok so if there is anyone out there wanting to talk to owners of diffrent cars and cant find them ie; not a member, than please ask if anyone knows of that car or owner in this thread ie; seen a nice car the other day and wouldnt mind talking to its owner, i would like to talk to the owner of the plate YBSKRD n.s.w and that awesome blue r33 by the name of WEAPON if any knows these guys it would be great if u could tell them to send me a line.
https://www.sau.com.au/forums/topic/72224-owners-wanted/
Gruntn, I can't help you out with meeting up with him but I know his name if that helps. I'll PM it to you if you want it.
BTW you've got to see the size of the turbo he's got under the bonnet (3240? 3540? Can't quite remember). I've seen him getting it a little sideways down Stewart Ave a few times, so he certainly likes to use it too :rolleyes:
https://www.sau.com.au/forums/topic/72224-owners-wanted/#findComment-1330680
no need for his name thankx mic33r- how the f r u going any way i see ur selling the 33 good luck. thats one bigg turbo, either one of those suckers,im realy looking for the owner of ybskrd (why be scared) n.s.w blue and white plates he is from sydney , just wondering if the weapn was still around havent seen it for awhile.good to see a good car still thumpen around newi.cheeers
https://www.sau.com.au/forums/topic/72224-owners-wanted/#findComment-1330805
cool which sort of toyota? mmm burnt out hey :flamed: thats not a good thing ,hey mic importing can sum times be quicker than buying a dunnydore from holden lol so just hang on mate and let us know how u go with ya new toy.
Toyota Chaser. There are some pics of it somewhere on the forum. Do a search for 'JZX100' and you should find them.
I've heard how long it can take to get a new car from Holden/Ford. It's crazy how long the waiting list was on the XR6Ts when they first came out. When I get it, I'm sure you'll see it around. I'll be driving it every second of the day :P
https://www.sau.com.au/forums/topic/72224-owners-wanted/#findComment-1331903
WEAPN did burn, it was near the john hunter hospital roundabout. Apparently that is what will happen when you do your own fuel system. (the fuel system story is just the most common one i have herd so dont take it as gospal). He has rebuilt it though and it is now a candy purple, i see it getting round sometimes.
https://www.sau.com.au/forums/topic/72224-owners-wanted/#findComment-1339386
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
