Something similar to this has been asked at least three times in the last 6 months.  Have a search.  You can use GTT* and GTR* as search terms.
thanks, tried search fond lots regarding r32s and r33s, but nothing on R34s though :) :headspin:
anybody else could help? appreciated
hey Guys,
Some info.... the r34 gtr bonnet wont fit the gtt unless u change the front bumper and also quater panels!....it can be done buy cutting the r34gtr bonnet but i dont think u want to do that with carbon fibre..its a bit wider and also u have to worry about the front lip ..
:cheers:
hey Guys,
thx mate, i have spoken to powerplay imports in sydney they reckon they have fitted a R34GTR bonnet to a GTT before, the bonnet is not wider so no quater panels needed, the only modification needed was to change those rear hinges(but some how they did not do it).
as for the gap between where the standard gtt bar meets the gtr bonnet, i have managed to source an "east bear" bonnet lid extension, which sort it out nicely (see pics)
but i still needed to find someone who can change these hinges.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
