Well yesterday was the first day of full wet weather driving for me in my car since ive had it. (Almost 3mths)
I think in the future i might just walk/ride to work (5km).
Driving my old car i knew the limits of how hard i could push before wheels would slide and brakes would lockup. In this car (R33 GTS-T) I dont.
* 90 Degree corners are near impossible under any accelleration.
* My mats get dirty
* Pedals are slippery and squeaky (can anyone recommend a good set of legal pedals for rubber soled shoes?)
On a good note, i cant use turbo or drive fast so im saving heaps of fuel.
:D
https://www.sau.com.au/forums/topic/7254-wet-weather/
yeh in my car you may as well be driving on ice if it comes on boost. off boost it's fine though :D You just gotta know to expect the odd step-out when going round corner's etc... and be prepared for it :)
on a side note I'm really glad the rain's arrived so that the bushfires can be put out. I'm sure the people who almost lost their homes are very thankful as well :) very good news :)
https://www.sau.com.au/forums/topic/7254-wet-weather/#findComment-106769
no offence meant but...
don't you think that you might be over reacting there. well, it's either that or you can't drive:rolleyes:
i found wet wether driving to be one of the more exciting things about owning a rwd. sure it's dangerous and you can slide out easy but it's damned fun
https://www.sau.com.au/forums/topic/7254-wet-weather/#findComment-106777
Im in both boats for this...
Jumping for a N/A car into a turbo RWD is so much different.
The driving styles are totally different... Usually u would have to
give it some gas around the corners in the N/A so not knowing
what to expect in the sky you would do the same..give it some
gas...heehhea. i bet u got a big fright benm not expecting it..
and yes it is fun in wet.. u get to know u'r tyre limits and how
you car reacts once traction breaks loose...
https://www.sau.com.au/forums/topic/7254-wet-weather/#findComment-106799
Exactly....
I've gone from a N/A 50kw FWD car to a Turbo 192rwkw RWD Car.
The last time their was a light shower of rain (enuff to wet the roads but not enuff for wipers) it brought all the dirt and oil to the surface and some 90 degree corners i literally slid out just turning them (w/o accelleration).
I'd love to go to a track day even just to do 5-10 laps so i can work out the limits of the steering. My old FWD car as u all would expect wasn't the best at cornering so im very cautious with the skyline.
:burnout:
https://www.sau.com.au/forums/topic/7254-wet-weather/#findComment-106801
etc etc
exactly driving in the wet is fine unless your a bad driver...
???? im confused, how do you drive in the wet ?? sorry im confused.
https://www.sau.com.au/forums/topic/7254-wet-weather/#findComment-107005
During the rain i switched from the Skyline to a gutless BMW 318. lots different. you can floor it and reef it around corners (in a way that would write off your skyline) and it still wouldn't unstick. its so much fun doing it in the Line' tho. Especially trying to perfect your wet road launching technique
One other thing i've noticed: Why do people seem to tailgate even more in the wet??? it seems like the rain is a signal for every brick-headed tailgater to come out for a drive (just stay off my ass!):shake:
https://www.sau.com.au/forums/topic/7254-wet-weather/#findComment-107534
DON91E i think they referring to u buddy!
ease up!
hahahahah:D
https://www.sau.com.au/forums/topic/7254-wet-weather/#findComment-107693
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
