  • Replies 214
Ok.
Everyone who chose to deposit 50% now 50% later. It's later.
Same as before deposit the rest of the money and email me receipt.
Thanks guys.
Also,
Some notes from WSID
1.Two drivers to one car: No problem. But both drivers MUST present themselves at the same time for credentials. It won’t be permitted as an “afterthought”. There will not be any change to the pricing structure.
2.Track preparation: The track will be prepared at least to Street Meet level. That means the track will be spayed for the first 60-80 feet and have the tyre machine dragged over it for two-plus hours.
3.Burnout Pad access: No; can’t do this for you. As explained earlier, this activity changes the sanction fee considerably which would need to be added to your track hire fee. It doesn’t matter how briefly someone may wish to use it.
4. seating: Please advise your people that no one is permitted into the gold seating area. The adjacent grass-terraced area at the north-western corner of the spectator area is an excellent area that provides an overall view of the venue. Perhaps you could suggest that people bring a blanket and/or cushions for their comfort.
Ok
t]
dam!!!!
is there a rule about burnouts on the strip?
for example if i want to over excesively warm up my tyres?
I would imagine that this would be ok provided it wasn't to continue for minutes, ie your still sitting there warming up your tyres and the other bloke is complaining as his have gone cold.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
