  • Replies 214
Ok.
Everyone who chose to deposit 50% now 50% later. It's later.
Same as before deposit the rest of the money and email me receipt.
Thanks guys.
Also,
Some notes from WSID
1.Two drivers to one car: No problem. But both drivers MUST present themselves at the same time for credentials. It won’t be permitted as an “afterthought”. There will not be any change to the pricing structure.
2.Track preparation: The track will be prepared at least to Street Meet level. That means the track will be spayed for the first 60-80 feet and have the tyre machine dragged over it for two-plus hours.
3.Burnout Pad access: No; can’t do this for you. As explained earlier, this activity changes the sanction fee considerably which would need to be added to your track hire fee. It doesn’t matter how briefly someone may wish to use it.
4. seating: Please advise your people that no one is permitted into the gold seating area. The adjacent grass-terraced area at the north-western corner of the spectator area is an excellent area that provides an overall view of the venue. Perhaps you could suggest that people bring a blanket and/or cushions for their comfort.
Ok
t]
dam!!!!
is there a rule about burnouts on the strip?
for example if i want to over excesively warm up my tyres?
I would imagine that this would be ok provided it wasn't to continue for minutes, ie your still sitting there warming up your tyres and the other bloke is complaining as his have gone cold.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
