hey guys,
i recently brought a r33 skyline just recently when i come on boost its a high ptich spoolin noise( thats been happenin for ages) but yea when i acutally hit boost it doesnt pull really at all..it goes to its 12psi wat its running but doesnt pull, its wired...i think it may be turbo. im goin to look right now to see if its piping but yea any help would be great..
cheers Adam!
turbo gasket - i got the same with my 180sx. - sounds like very sharp metal ball bearing whistle sound. its the turbo gasket.
shaun
i have a similar thing with mine, sort of, i have the noise but the turbo still pulls? i've been told that the nosie is when the turbo has over spun?? though come to think of it there is one bolt or nut missing from where the turbo bolts to the manifold??? also when my clutch let go there was no pull from the turbo, not much forward anything, but you would notice how fast it would rev out though!
