GDay,
Im in the process of putting an RB26 in my R32 gtst. Its a full rebuild engine with all the forged stuff and a single 700hp garrett high mount turbo. The guy who has done the engine work, and who will be modifying the exhaust, has recommended a new 3.5inch exhaust. I currently have a stainless 3inch turbo back system which cost around $2000. I dont want to upgrade if its unneccessary.
My question is:
Will a 3inch exhaust be sufficient for around 350rwkw maximum?
If not, is four inch better?
I have been told (and read) that anything greater that 3inch is overkill. Is this correct for my application?
Any advice from people with first hand knowledge in this area would be appreciated.
Shaun.
Try the one you have ATM it shouldnt be throttling/choking the engine. my freinds car just dyno'd 394rwkw with a 3" exhaust its a rb30det with a big single KKK turbo.
Then he took off the cat and put a straight thru pipe and dynoed 412rwkw!
you cat might hold you back but the exhaust will prob be fine for your application
My GTR R33 has been dynoed at 412awkw and I have a 3" exhaust system.
The thing is when I removed the external wastegate pipe to be plumped out to atmosphere I picked up another 5kw.
This is using a straight through pipe as my cat which was also at 3" but I am now ungrading to 3.5" system as there is more power there.
There are no gains above this and the outlet on the turbo would be no greater then 3.5" so there is no point in going any larger.
Your exhaust system is as big as the smallest point in the system.
I don't want to to this as well as I am so very happy with the way my car sounds and don't want to lose it but the extra power is just sitting there doing nothing....
The following modifications are as follows:
RB26 ENGINE
HKS 88MM FORGED PISTONS
HKS CON RODS
HKS STEP 2 280 CAMSHAFTS
HKS CAM GEARS
HKS 1.6MM HEADGASKET
JUN OIL PUMP
PERFORMANCE METALCRAFT 8L RACING SUMP
PORTED HEAD
NISMO BEARINGS
NISMO CAMBELT
AUTRONIC SMC AND LOOM
1000CC INJECTORS
BLITZ FUEL RAIL
MALPASSI FUEL REG
SPLITFIRE COIL PACKS
GARRET BALL BEARING TURBO(NEW T04Z) - RACEPACE CUSTOM
RACEPACE CUSTOM EXHAUST MANIFOLD
TRUST EXTERNAL WASTEGATE
NISMO G-MAX TWIN PLATE CLUTCH
HKS GT SPEC DRAG INTERCOOLER
CUSTOM FUEL SWIRL POT - TWIN OUTLETS FED BY GTR FUEL PUMP
2 X BOSCH 044 EXTERNAL FUEL PUMPS
HKS OIL COOLER KIT
TRUST EXHAUST 3"
ARC ALLOY RADIATOR
ARC OIL CATCH TANK
HKS EVC4
HKS COLD AIR INTAKE
TUNED BY BEN @ RACEPACE MELBOURNE
CURRENTLY MAKING 417KW@THE WHEELS AT 1.3 BAR
WAS MAKING OVER 500KW WITH PREVIOUSLY FITTED HKS T51R
Cams make the engine lumpy like a V8 but it's idle is awesome.
I don't find any faults with street driving at all, has good power off boost and loooovvvves to rev and pull's hard all the way to redline @9500rpm.
Like to see if I pik up more power with a 3.5" exhaust, I think there is some left in it..... well just have to see
Generally a 3.5" is required up over 300rwkw to be 'optimal'.
I want to keep the noise down so I will be going a 3.5" dump in to a 3.5" cat, then a 3.5" pipe in to a intermediate muffler that splits the 3.5" in to 2 x 2.5" pipes, 2.5" pipes to the rear of the car where there is another large muffler, 2x 2.5" tips out of the muffler.
It will flow really well, not drone and sound quite nice. :D
Its very similiar to the XR6 APS exhaust system.
Hey cubes, this is a clever way of reducing the noise and still keeping the noise levels down....I like it :D
Q. How would a HKS Super Dragger Exhaust sound (3.5" straight through) on a built RB26?
This is what I was thinking of doing when I replace my 3" system to a 3.5" system.
Weird thing is I have a 3.5" system to the cat then 3" system to the rear :microwave
i'm not sure how the Super Dragger would sound.. Obviously loud.
My goal was to make the exhaust look fairly standard out the rear and sound as quiet as possible with no drone inside the cabin. The large intermediate muffler was the only way to go with 2 x 2.5" pipes.
Apparently a single 3.5" does flow better than 2 x 2.5" pipes but it is much louder.
  • 3 weeks later...
Ive just sold my 3 inch exhaust in favour of going to 3.5. Can anyone recommend a japanese brand exhaust that has the following features?:
• Stainless steel
• Sits nice and close to the body. Ive heard that some jap exhausts hang down too low.
• Isnt offensively loud so that it attracts cops.
Also, if anyone has info relating to where i can get such an exhaust, can you let me know?
Any feedback would be appreciated.
Thanks,
Shaun.
0414972596
I would highly reccomend a Trust TR (they are 3.75 inch i think) they fit the bill for your requirements except for the stainless steel part which is really nothing major. The silencer system they have is very effective and they make room for large power increases.
Advan Perfromance in Silverwater stock them - 9647 1326
IMO a japanese car needs a new japanese exaust.
Believe it or not but japanesemotorsport have much better prices on the trust exausts. I think mine was around 1200 delivered(2years ago), took me minutes to install, not much louder than stock at idle, great note, no drone, etc, etc.
Do not commit the sin of the australian made catback system., it will look and sound like shite, not to mention being the japanese ones are typically designed on CAD software.
Support local front/dump pipes instead!!!111@2
For look, sound, performance you cant go past a japanese system, stuff the price :wassup:
Ha Ha, Funny sh1t! Thats exactly what im doing. Ill give JMS a ring, but if im gonna pay the dollars i think i want stainless. I might look into Apexi.
Guest two.06l
Give Peter a ring at Advan, they get some great TRUST front pipe copies made up...you would be hard pressed to tell the difference!
P.S. why do you want stainless?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
