GDay,
Im in the process of putting an RB26 in my R32 gtst. Its a full rebuild engine with all the forged stuff and a single 700hp garrett high mount turbo. The guy who has done the engine work, and who will be modifying the exhaust, has recommended a new 3.5inch exhaust. I currently have a stainless 3inch turbo back system which cost around $2000. I dont want to upgrade if its unneccessary.
My question is:
Will a 3inch exhaust be sufficient for around 350rwkw maximum?
If not, is four inch better?
I have been told (and read) that anything greater that 3inch is overkill. Is this correct for my application?
Any advice from people with first hand knowledge in this area would be appreciated.
Shaun.
Try the one you have ATM it shouldnt be throttling/choking the engine. my freinds car just dyno'd 394rwkw with a 3" exhaust its a rb30det with a big single KKK turbo.
Then he took off the cat and put a straight thru pipe and dynoed 412rwkw!
you cat might hold you back but the exhaust will prob be fine for your application
My GTR R33 has been dynoed at 412awkw and I have a 3" exhaust system.
The thing is when I removed the external wastegate pipe to be plumped out to atmosphere I picked up another 5kw.
This is using a straight through pipe as my cat which was also at 3" but I am now ungrading to 3.5" system as there is more power there.
There are no gains above this and the outlet on the turbo would be no greater then 3.5" so there is no point in going any larger.
Your exhaust system is as big as the smallest point in the system.
I don't want to to this as well as I am so very happy with the way my car sounds and don't want to lose it but the extra power is just sitting there doing nothing....
The following modifications are as follows:
RB26 ENGINE
HKS 88MM FORGED PISTONS
HKS CON RODS
HKS STEP 2 280 CAMSHAFTS
HKS CAM GEARS
HKS 1.6MM HEADGASKET
JUN OIL PUMP
PERFORMANCE METALCRAFT 8L RACING SUMP
PORTED HEAD
NISMO BEARINGS
NISMO CAMBELT
AUTRONIC SMC AND LOOM
1000CC INJECTORS
BLITZ FUEL RAIL
MALPASSI FUEL REG
SPLITFIRE COIL PACKS
GARRET BALL BEARING TURBO(NEW T04Z) - RACEPACE CUSTOM
RACEPACE CUSTOM EXHAUST MANIFOLD
TRUST EXTERNAL WASTEGATE
NISMO G-MAX TWIN PLATE CLUTCH
HKS GT SPEC DRAG INTERCOOLER
CUSTOM FUEL SWIRL POT - TWIN OUTLETS FED BY GTR FUEL PUMP
2 X BOSCH 044 EXTERNAL FUEL PUMPS
HKS OIL COOLER KIT
TRUST EXHAUST 3"
ARC ALLOY RADIATOR
ARC OIL CATCH TANK
HKS EVC4
HKS COLD AIR INTAKE
TUNED BY BEN @ RACEPACE MELBOURNE
CURRENTLY MAKING 417KW@THE WHEELS AT 1.3 BAR
WAS MAKING OVER 500KW WITH PREVIOUSLY FITTED HKS T51R
Cams make the engine lumpy like a V8 but it's idle is awesome.
I don't find any faults with street driving at all, has good power off boost and loooovvvves to rev and pull's hard all the way to redline @9500rpm.
Like to see if I pik up more power with a 3.5" exhaust, I think there is some left in it..... well just have to see
Generally a 3.5" is required up over 300rwkw to be 'optimal'.
I want to keep the noise down so I will be going a 3.5" dump in to a 3.5" cat, then a 3.5" pipe in to a intermediate muffler that splits the 3.5" in to 2 x 2.5" pipes, 2.5" pipes to the rear of the car where there is another large muffler, 2x 2.5" tips out of the muffler.
It will flow really well, not drone and sound quite nice. :D
Its very similiar to the XR6 APS exhaust system.
Hey cubes, this is a clever way of reducing the noise and still keeping the noise levels down....I like it :D
Q. How would a HKS Super Dragger Exhaust sound (3.5" straight through) on a built RB26?
This is what I was thinking of doing when I replace my 3" system to a 3.5" system.
Weird thing is I have a 3.5" system to the cat then 3" system to the rear :microwave
i'm not sure how the Super Dragger would sound.. Obviously loud.
My goal was to make the exhaust look fairly standard out the rear and sound as quiet as possible with no drone inside the cabin. The large intermediate muffler was the only way to go with 2 x 2.5" pipes.
Apparently a single 3.5" does flow better than 2 x 2.5" pipes but it is much louder.
  • 3 weeks later...
Ive just sold my 3 inch exhaust in favour of going to 3.5. Can anyone recommend a japanese brand exhaust that has the following features?:
• Stainless steel
• Sits nice and close to the body. Ive heard that some jap exhausts hang down too low.
• Isnt offensively loud so that it attracts cops.
Also, if anyone has info relating to where i can get such an exhaust, can you let me know?
Any feedback would be appreciated.
Thanks,
Shaun.
0414972596
I would highly reccomend a Trust TR (they are 3.75 inch i think) they fit the bill for your requirements except for the stainless steel part which is really nothing major. The silencer system they have is very effective and they make room for large power increases.
Advan Perfromance in Silverwater stock them - 9647 1326
IMO a japanese car needs a new japanese exaust.
Believe it or not but japanesemotorsport have much better prices on the trust exausts. I think mine was around 1200 delivered(2years ago), took me minutes to install, not much louder than stock at idle, great note, no drone, etc, etc.
Do not commit the sin of the australian made catback system., it will look and sound like shite, not to mention being the japanese ones are typically designed on CAD software.
Support local front/dump pipes instead!!!111@2
For look, sound, performance you cant go past a japanese system, stuff the price :wassup:
Ha Ha, Funny sh1t! Thats exactly what im doing. Ill give JMS a ring, but if im gonna pay the dollars i think i want stainless. I might look into Apexi.
Guest two.06l
Give Peter a ring at Advan, they get some great TRUST front pipe copies made up...you would be hard pressed to tell the difference!
P.S. why do you want stainless?
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
