Al, I've got to agree with Troy, go to Wilko's they will supply, fit and align then with the new bushes, makes a difference to the handling too:D
Paul,
Can you tell me roughly how much are they and where is Wilko's.
And how much of a mamber discount do I get?
cheers
Al
I got mine done 2 mnths ago at Glenmount Automotive, polyurathane bushes also, cant remember exactly how much it cost as i had a few other items getting fixed but it was about $120 installed. Wont hurt to get a second price.. Ph- 9544 4000
']Al, i am in the same position as you, my bushes are fu*ked been like that for along time. i think ken told me it was about $200 each to replace
How can that be, when the front rotor cost that much, how can a piece of rubber be that much......Ken must do a wheel and suspension check for that price.
I seriously think something is wrong with that price. $200 is more realistic to replace all of the bushes on each side.
I know the upper arm bushes need to be done by a specialist. I looked in the manual and it's no big deal.....to do the bottom ones.
Well if that is the case this Skyline won't be seen north of the river......
:flamed:
:flamed:
:rofl: whoops it wasnt the bushes, i got price for (i feel really smart now :P) it was the castor rods hehehe closes enough :rofl:
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
