Can someone help me with this? I have an R34 GT-T and I know I have it setup right but this boost controller does'nt seem to work on my car... it builds boost up to the 12 psi I want... but then at 4.5k rpm-redline, it drops off down to 6psi... anyone know why this is? I've installed many many boost controllers and have never had a problems with this untill I've started using manual boost controllers on my cars.
It could be your headlights have a bad earth!
Sorry, I thought I would make some crap guesses too.
Have you checked to make sure the factory control solenoid has been disconnected as this will limit your boost to 6-7psi once the ECU detects overboost? And on the R34's the boost cut is around 12psi.
Thankyou, please come again.
  • Replies 1.8k
Posted Images
Installed mine yesterday. Started at 5psi felt like stock, wound up to 10psi, felt like my ECU didn't like it but it hammered, wound down a fraction and got 7psi up until 5000rpm where it just reached 8psi... Quite happy, and you DO feel it come on boost quicker.... and i'm running stock everything else!
The bottom end (opposite from the allen bolt) goes to your intake pipe (that goes directly to your throttle body, the side feed goes to the turbo (wastegate actuator), and the last hose left over will come from the pipe that leads to the BOV. put a nice big screw into it, then hose clamp the pipe over the screw to make sure it doesn't come out. The factory solanoid can be completely unplugged (hoses) and left hooked up to the ECU (wiring).
Chalk up another satisfied turbotech customer. :)
When my first one did not turn up in the post mark sent a second one out for free. The first one ended up return to sender to him the day i recieved the second one in the mail.
Easy to install, first run out with no adjustment ran completley steady 10psi (exactly the amount i wanted) with no spiking or drop off at high revs that i've seen sofar. I also agree with what others have said that the car seems to get on boost earler, okay its not a massive increase, but the product performs like something 5 times the cost IMO. Highly recommended :)
I brought one a while ago and I love it I dont think ATM I will have a need for a electric Boost controler for a while as I have no need to boost that high. I own a GFB and that thing spiked like crap this has a little spike but its 1 PSI Who cares about 1 PSI and it hold all the way to the red line very nice I love it.
when you say "factory solenoid can be completely unplugged", is that just the 2 stock hoses that can be unplugged, do i need to loop these solenoid nipples?
The two hoses from the stock solanoid can be removed completely. The solanoid can just sit there with nothing connected to it. You're bypassing it completely... although... if you hide the new boost tap, you might want to run some long black hoses in a loop off the solanoid so that it looks connected to something. (sleeper style)
I too am another happy customer. Installed it as it came and my poor little standard turbo went upto 1.2bar... so a minor alteration and Ive bumped it back to 1bar.
Too easy! EBC Killer!
JK
how come i can't seem to access the link on page one to buy it :P i really wanted one ....*cries......I WANT ONE!!!!....where can i buy it? can;t find in ebay search..dunno where else .... can you please help out a friend in need of more boost?....*sobs
email [email protected] and ask him to send you one
Sam was the person who actually co-designed them.
I had my car tuned by Dr Drift on Saturday and swapped my Leakosmart Dual Stage EBC for one so I could get over 16psi. Running very nicely on 19 now!
Edited by 3lit3 32
[email protected]
say u want one, he'll give u bank details, deposit and give him ur address, and thats pretty much it.
this still holds for those who want to email the guy who appeared here directly. should read the whole thread, but i guess at 100 pages its a bit much to expect :D
maybe a mod can edit this into the first post so people know what to do?
Hi,
my knowledge is limted with boost units,
I just email to buy 1 as well,
can some 1 give me instructions oh how to install them?
Maybe it mentioned b4, in this thread, but its been 31 pages,
and GOOD son of rajab I can not read them all, i must have missed it.
Thanks alot for ur helps,
cheers,
darrien
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is [email protected]
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
    • Cam seals go hard. It's a very old car.
