  • Replies 1.8k
Posted Images
hey guys
i bought this item on ebay about a week and a half ago, and paid via paypal straight away. i havent had any word from the seller about delivery. ive emailed him and left msgs on his ebay account, but still had no contact with him. does anyone know how else to get incontact with him? im just a bit worried that my item wont get sent out and ill loose my money
cheers
mark
Guys this little gadget is the KICK my GTT needed!!!
Car feels so much quicker and just kicks in boost as soon as u touch the accelelator!
Winds up very nicely and holds the boost hard.
I'm not too mechanically wise but as a driver, I can feel the difference and its only been set to around +-9 PSI from first go.
As you can see... clear winner under my bonnet... and it took only about 5 minutes to install... mainly because my hoses were there already connected to the Profec EBC unit thing so it was clear from there what to do.
Also, I payed on Friday, got it today (tuesday). Pretty much next day delivery!
Thanks SidMark!
Edited by Alien
36 pages is well deserved for such a cheap, simple, effective product! Like Alien said... i've set mine to 7psi (no mods) instead of doing the solanoid trick, and because it is not a bleed system, it winds on boost so much quicker than before!
I boost at about 2200rpm at 7psi, and the stock setup would boost at 3000rpm at 5psi (dual stage stuff).
i bought one off ebay a few days ago but it wasn't the turbotech, looks exactly the same.
this thing is the best $30 performance mod i have made, my car was running the GFB unit and it worked s__t spiking all over the place. after i installed it my car held boost to 18psi like an EBC im just wrapped with it and it boosted so much faster than i expected about 2200 rpm.
Should be taking to track soon.
Heh.. it's not a Turbo-smart... This guy makes all these on his own! I beleive he goes over it and checks the mechanism before sending it out, so i'd expect that he's probably a bit swamped making and sending them while working his other full-time job. =-]
i bought one a couple of months ago but only just got around to putting it in. I still have to make a few changes but the one trouble i have is that it is overboosting really bad...
I put my foot down and it will go up 13 - 15psi then drop down and hold at around 9 1/2psi
I have checked the lines and they are about as short as i can make them with very little angle to any of them ??? any advice would be appreciated.
Cheers Leigh
A mob called JRD have copied the design and are flogging them of $5 cheaper than marks.
It says something about the quality of the design if there are already cheaper knock off's floating around
Hey guys,
Has anyone heard from Mark lately? I brought a unit from him two days ago, emailed him twice and have heard nothing.. I need the unit by tomorrow as the car is going to the mechanics for a variety of other things and i wanted to get it all done.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
