Hey guys,
Has anyone heard from Mark lately? I brought a unit from him two days ago, emailed him twice and have heard nothing.. I need the unit by tomorrow as the car is going to the mechanics for a variety of other things and i wanted to get it all done.
heya, i ordered the part like a week and a half ago, and got the part yesterday in the mail.
was a little delayed but i suspect Mark doesnt get on the net very often.
hope you get it in time!!!
will be installing tonight i think
cheers
  • Replies 1.8k
Posted Images
Put mine in last night and have a quick test today on the way to work. Apart from the boost a little high, it works awsome. Boost alot quicker and the BOV is louder. Ill adjust the boost after work and give it a good run. Awsome mod for $35!! Very happy here :happy:
I have to tell you how well with controller works on my skyline
got a 700hp gt3540 with a 38mm ext gate 3l bottom end
Went to C&V for a tune and everyone there was very skeptical about using that boost controller on my car with those kind of mods except the tuner Con who said "i will allways try something once"
We put it on and set it and the boost curve was just perfect. Con could not believe how well these boost controller works. The curve looks like something an eboost will hold.
So yeah if anyone wants to use this on a externaly gated turbo it worked for me.
A mob called JRD have copied the design and are flogging them of $5 cheaper than marks.
It says something about the quality of the design if there are already cheaper knock off's floating around
Competition, is good for us the customer.
Yeh i bought it off JRDSPORT top serivce and has helped me with aftermarket service on how to install as i was having trouble, i asked him what was the difference between his boost controller and turbotech, he said that his boost controller has a different spring rate for faster turbo spool. Oh well im happy. great product, great service and great price.
i bought one a couple of months ago but only just got around to putting it in. I still have to make a few changes but the one trouble i have is that it is overboosting really bad...
I put my foot down and it will go up 13 - 15psi then drop down and hold at around 9 1/2psi
I have checked the lines and they are about as short as i can make them with very little angle to any of them ??? any advice would be appreciated.
Cheers Leigh
same thing is happening to mine, plus ther is a sound that is awefully bad if i plant my foot down. if i slowly put it down then ther's not 2 much to worry about, but lets say i jus dcided 2 go pedal 2 metal for a gear....about 3000-redline its got a shredding kind of sound. Ive got a hi-flowed stock turbo, n was like WTF wen i put it in. great toy though :P would recommend to anyone and everyone!
i have the same issue on one of the two i have i think. ie one spikes badly the other spikes at most 0.5 psi. ive emailed mark to see if theres anything that could go wrong with it to cause this, cause my other one worked fine
I fitted mine today, its set at 10psi, but a wierd thing happens say im boosting hard in 2nd change in to 3rd and quickly jump off the throttle my guage for some reasons jump VERY quickly to 15-20psi and then straight to 0psi...Is that normal?
NOT NORMAL!!!
if u set at 10psi and it spike to 15-20 psi! OMG
did u disconeccted the stock selonoid?
or u hooked them up wrong way around?
happened to me,
i keep geting max boost, spike 15-20psi! turn out i have to remove the stock selonoid!
So NewKleer do you know if there are two different spring rates and that sounds dodge as it ones fine and hte other isnt. I am going to set mine up again on the weekend with thicker hoses and make them even shorter if possible... hopefully that will fix my problem.
on the diagram above it looks like the bottom adapter on the boost controller below goes into the IC piping which is wrong. shouldnt it be the bit that points to the right ??? as such you can adjust the boost from the top ??? seems logical to me
anyways if i am wrong that would possibly explain my spikage but it just doesnt look right ???
The adjuster is what preloads the spring to hold the ball in place until it reaches the set level. So it needs to read boost from the bottom of the device not the side. It would be too complicated to make otherwise.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
