Hehehehe.
No offense but I have just flicked through this whole topic starting from posts at the beginning of this year and I have noticed 1 thing in particular.
I don't want to start anything but it seems like we have someone either who works for JRD who sells their copies of Turbotech.
Can anyone see this?
Here's a clue - r33kid
Most of his posts are all to promote against Turbotech boost controller
  • Replies 1.8k
Posted Images
i just fitted one yesterday, these are fantastic boost controllers, i got mine within a week of paying. b4 hand i had a turbosmart bleed valve an it sucked ass, full boost by 3100 all the way through to redline.
very happy with this product.
lol aquariuz6.
Nice pickup, definitely smells fishy.
http://www.skylinesaustralia.com/forums/in...hlite=%2Br33kid
For those that don't know select to preview each indivudual post.
Hehehe.
I would laugh if thats the JRD guy on ebay.
He just joined SAU to push people into buying his copied item.
How low can you get, jacking a thread that began on Mark's boost controller
Wouldn't be surpised since Mark actually added the link to this topic on ebay.
Hi,
I have a R32 and im running a R34 Turbo on my RB20DET. I installed the boost controller on my car a few weeks ago but I couldnt get it working proberly. The first time I took the car for a run the boost wasnt coming on much at all and the car felt held back. I then turned up the boost and could feel the difference but my boost gauge wouldnt read above 10psi. I turned it up more but still nothing changed. I was reading through this post and people with R34's were having the same problem. I was reading something about disconnecting the solinoid but I wasnt sure what that was. Does anyone know what my problem could be and how I could fix it?
Thanks!!
I thought the wastegate setup on a 32 was set at 10psi which is why R33 owners will by R32 actuators for a simple 10psi? Someone feel free to correct me here as I don't own a 32.
Yeah the standard boost is 10psi and im wanting to run 12psi. Im gonna try putting the boost controller back on today again. Can I just cut the hose and add the Controller in or is there something else I will have to cut? Last time I put it on I couldnt get the boost gauge to read over 10psi.
Thanks
I don't work or know the owner of JRD all i have done is purchase there product, the reason i have pushed there product is because of the poor service that was offered to me by mark, whom i don't know personally.
Once again, i am not affilated with JRD in any way shape or form.
You can beleive what you like, free country.
Hehehehe.
Just so i do the job right, and without looking at 50+ pages, anyone help me out with installation on this?????
Pics would be great!
I know i know im useless...
34 GTT.
Thanks.
installing on the r33. after bypassing the solenoid, blocking, removing etc, do you need to disconnect the wiring/plug that goes to the stock solenoid?
also, the boost controller i got from mark has no hole drilled in it. mark said it's a new design, hole is no longer required. it went a bit silly when i first tried it. so i pulled it apart to check inside, and will try again.
has anyone else got one without the hole that's working properly?
huh? what ?
o....k
i got mine 2 days ago.
anyway
yeah i will let you know. i still want someone to tell me if i need to disconnect the wiring/plug going to the solenoid, or if it doesnt matter.
wont be trying it in this sydney rain anyway. so i guess it will be a few days before i have a result.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
