Hehehehe.
No offense but I have just flicked through this whole topic starting from posts at the beginning of this year and I have noticed 1 thing in particular.
I don't want to start anything but it seems like we have someone either who works for JRD who sells their copies of Turbotech.
Can anyone see this?
Here's a clue - r33kid
Most of his posts are all to promote against Turbotech boost controller
  • Replies 1.8k
Posted Images
i just fitted one yesterday, these are fantastic boost controllers, i got mine within a week of paying. b4 hand i had a turbosmart bleed valve an it sucked ass, full boost by 3100 all the way through to redline.
very happy with this product.
lol aquariuz6.
Nice pickup, definitely smells fishy.
http://www.skylinesaustralia.com/forums/in...hlite=%2Br33kid
For those that don't know select to preview each indivudual post.
Hehehe.
I would laugh if thats the JRD guy on ebay.
He just joined SAU to push people into buying his copied item.
How low can you get, jacking a thread that began on Mark's boost controller
Wouldn't be surpised since Mark actually added the link to this topic on ebay.
Hi,
I have a R32 and im running a R34 Turbo on my RB20DET. I installed the boost controller on my car a few weeks ago but I couldnt get it working proberly. The first time I took the car for a run the boost wasnt coming on much at all and the car felt held back. I then turned up the boost and could feel the difference but my boost gauge wouldnt read above 10psi. I turned it up more but still nothing changed. I was reading through this post and people with R34's were having the same problem. I was reading something about disconnecting the solinoid but I wasnt sure what that was. Does anyone know what my problem could be and how I could fix it?
Thanks!!
I thought the wastegate setup on a 32 was set at 10psi which is why R33 owners will by R32 actuators for a simple 10psi? Someone feel free to correct me here as I don't own a 32.
Yeah the standard boost is 10psi and im wanting to run 12psi. Im gonna try putting the boost controller back on today again. Can I just cut the hose and add the Controller in or is there something else I will have to cut? Last time I put it on I couldnt get the boost gauge to read over 10psi.
Thanks
I don't work or know the owner of JRD all i have done is purchase there product, the reason i have pushed there product is because of the poor service that was offered to me by mark, whom i don't know personally.
Once again, i am not affilated with JRD in any way shape or form.
You can beleive what you like, free country.
Hehehehe.
Just so i do the job right, and without looking at 50+ pages, anyone help me out with installation on this?????
Pics would be great!
I know i know im useless...
34 GTT.
Thanks.
installing on the r33. after bypassing the solenoid, blocking, removing etc, do you need to disconnect the wiring/plug that goes to the stock solenoid?
also, the boost controller i got from mark has no hole drilled in it. mark said it's a new design, hole is no longer required. it went a bit silly when i first tried it. so i pulled it apart to check inside, and will try again.
has anyone else got one without the hole that's working properly?
huh? what ?
o....k
i got mine 2 days ago.
anyway
yeah i will let you know. i still want someone to tell me if i need to disconnect the wiring/plug going to the solenoid, or if it doesnt matter.
wont be trying it in this sydney rain anyway. so i guess it will be a few days before i have a result.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
