i'd be looking at the new intake. more likely to be that rather than the boost controller, since the boost controller isnt doing anything when your off boost.
new intake as in what? new pod? new intake pipe? new plenum? has your afm been messed around with?
i tightened it up to 10psi and i havent had the stalling prob again yet... i dunno, just mustve been something weird...
  • Replies 1.8k
Posted Images
I have had mine running without the restrictor and it sux, the screw is bearly in and the boost is very hard to controll. Myabe mine is dogey, i have had mine appart to chech everything and no good, going to test a mates one and see if it work ok.
having the restrictor in means that there is less pressure after it/before the controller. this means that the screw has to be looser to keep the boost pressure at the required level. having the restrictor out means that the controller is getting the full pressure, so the screw has to be further in to stop it being forced open.
i don't have a restrictor in mine. i put a new bit of hose on there. didn't seem to affect it at all.
fugi- yes cubes instructions still apply. when he is talking about a bleed valve he is talking about a boost controller. doesn't matter what type.
Thanks man.
I will give it a try.
Edited by Fugi
nah the ball isint getting stuck ive had it apart a few times the spring looks really dodgy in it . reckon someone has had a play with it for what ever reason and buggered it i reckon the spring is too heavy for it to work as it should
Edited by mid life crisis
hey mad082, do you remember a while ago i did the 'high boost on stock solenoid' mod and my boost went infinite? couldnt work out what happened. well today i found a unichip piggybacked to my ecu that i didnt know was there. lol. now from what i understand, the unichip intercepts afr's, timing, and possibly boost, thru the ecu.
so i guess this may have been why it freaked out.
i might remove this BC when i find a tuner for the unichip, and set the boost thru the ecu, if it's possible. but it shouldnt hurt anything having it there for now, yeah?
there is no bleed valve on a 32. just take that hose off and get a longer piece and put it on with the controller in the middle of it.
munkyboy, is there any sort of solenoid being run off the piggyback? does it have a vacuum hose running to it?
no other solenoid besides the stock one.
there's no vacuum hose going to the unit.
yesterday the tuner that looked at it told me these are capable of controlling boost thru the ecu, if it's been wired up that way. so i dont actually know if it has been. there's an extra box connected to the unichip aswell, not sure what that ones for. he suggested possibly fuel cut defender type of thing. just guessing at this stage.
when i track down a reasonably priced tuner for unichip, all will be revealed.
edit: the turbotech seems to be doing its job, so i dont think there will be any issues with clashing interest between the ecu and the bc. whatcha think ?
Edited by Munkyb0y
generally once you do exhaust you get a boost rise.
munkyboy- how do they figure that it can control the boost through the stock ecu? i wasn't aware that the stock ecu could control boost other than the 2psi jump.
Ahh.. however when i brought the car my cuzin said that he too to the mechanics one day and the guy goes ohh i can put a bleed valve in for u. and he rcns he did.. is there certin places i can cheack just to make sure.. or is that the only place a bleed valve can go.
Edited by Fugi
dunno dude. that's what i was told. but i'm still not sure if it's the case with my unichip.
i'm guessing the stock solenoid gets the signal from the ecu to run a certain psi. i mean we know it can work for 5 and 7 psi. why not higher?
how long did u guys find him to take on sending the goods and replying back to emails....it has been 2 days since i payed and purchased the item, but he still hasnt even responded to the first email and payment confirmation.....
wats the deal ???
don't worry, i paid, got no confirmation and it just turned up one day. Very normal, don't worry about it, you'll get it. It's just the way he works, you won't get ripped, you'll get your part. 2 days, dude, just be patient.
It'll come :wave:
wats the deal ???
oooeeerrrr 2 whole days...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
