Hi people out there,
I was just wondering if anyone knows how hot their turbo's get. I know that this is a "how long is a peice of string" question but I am interested to know if anyone has gone for a drive or race perhaps and whacked a laser thermometer on their turbo just to see how hot it gets. Perhaps someone has read this info some where. If you have, then please tell...
Your tubo size and engine will make a difference in heat as smaller turbos run hotter, etc. Obviously, there would be an operating range depending on how hard you drive, etc. From what I understand the operating temp could be anywhere from 100 deg c to 1000 deg c! Anyone know?
Chriso
https://www.sau.com.au/forums/topic/73627-how-hot-is-your-turbo-do-you-know/
lol are you having fun posting this on every single forum, saw it on boostcruising ust before, now here :P
Oops... Busted. :Oops:
Yeah, bit of a forum hussy.
I had a tiny leak at my dump flange and needed to know how hot it get so I can get the right stuff. Looks like I won't need it anymore anyway as I found some loose screws... Still interesting to know though...
wow, you must be fast to jump out, pop the bonnet and look.
i've seen mine red but only on a dyno
i find it stays red for at least around 30 seconds and glows for a minute or so..
and yes i am usually quick, and when i have seen it i have been on a road in the middle of nowhere so no cars and is safe stop anywhere whenever :rofl:
Could be you're right. Damn hot anyway.
Means your trying hard enough :cheers:
btw a bit off topic but i wanted to ask you,
after u fitted the hicas lock bar, was there a difference in the weight of steering at any speed??
i ask this because im quite sure the steering weight varies depending on speed, and figure it might get stuffed up by locking the hicas..
Take a look in the tutorial , but the quick answer is yes it can get hard at low speed (40) due to the system being electrically variably loaded, according to speed. This is common but dissapears with extra caster.
I've had glowing turbo on stock r32 after hard mountain work.. I think its just a combination of having no dump pipe to dissipate the heat better, and the fact that the R32 turbo is pretty small. Could also be related to clogged water lines, but need to investigate this further.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
