Thanks for the love Jase :)
I'll let you catch up to my bill from spending money on car and see how you're feeling when you realise how many customer calls you have to answer to pay for a new turbo....:P
Cheers 600Zilla, i'm hoping mine may one day do the same!
https://www.sau.com.au/forums/topic/73647-property/#findComment-1356111
I bought a block of land up in Carramar about 6 months ago, however as nice as it is up there i wouldn't mind being a bit closer to the city or to Ossy park where work is. May we ask what suburb and general price range don't have to give exact just what the price range is. Reason being is i am looking for a funky 3 x 2 bath double garage villa or apartment around the $250G mark if anyone out there knows of somehting thats meets this criteria let me know :-)
well done on the purchase! its a good step in life to make!
https://www.sau.com.au/forums/topic/73647-property/#findComment-1356125
No worries Dan
It's in Booragoon (that's south of the river for all you northies) about a 2min walk from Garden City. It's not as big as a 3x2 mate, in that area, the best I could manage was a 2x1 with a decent backyard :rofl: Price was around the $260-270K mark. Also only a single carport/garage, but it's actually a drive through one so you can get two cars behind the roller door end to end.
Major debt club alright! I thought the $20K debt I used to have on my car was big enough!
https://www.sau.com.au/forums/topic/73647-property/#findComment-1357311
Its good to see I am not alone...... I just bought a block of land in Darch which is getting settled next week :P
Thought about selling the line and actually had someone ready with money in hand but I chose to keep the car at the last second..... I look forward to the next 25 years of being in debt :(
https://www.sau.com.au/forums/topic/73647-property/#findComment-1363650
U and every1 else. :rofl:
Id like to get somethig under the 220 mark, mmm no stamp duty. A long as it has one big living room a good kitchen and a decent sized outdoor/living area. ill be happy. Would be nice to be close to the city too.
Get that 1st home owners grant while u can.
https://www.sau.com.au/forums/topic/73647-property/#findComment-1363717
U and every1 else. :P
thats the plan :cheers: first homr owners grant and no stamp duty. seen afew i like, find out monday how much deposit i need for it.
https://www.sau.com.au/forums/topic/73647-property/#findComment-1364658
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
