  • Replies 330
Continued down to wisemans on Mona's directions, and have no idea how i got into leading the pack, but THANKS MONA, for sending us to the WRONG side of wisemans LOL.....ill let you off though cause you caught us a ferry :)
;) hey!! its not my fault!!! it was either that or make you head back to hornsby to take galston to wisemans.. that'd take forever.. nooone would have waiting :D plus i knew the ferry would get you to the right side of the woods! ;)
i say stick with the candy red idea thomas.
too many people want purple! i'd prefer bayside than it.
i agreee!!!!! that purple is going on myyy car!!! don't copy me thomas!!!!! :P
hahaha dean thats cause he has "minties mods"......done on his battery and fuel pump... ;)
hehhe hey i just got my car back ok.!! have to test it out!!!at one stage i freak out..shit man i stuck in the mid of the bush for de nite...i was last in the pack so everyone were nowhere to be seen, lucky some of my mate drove back to check up on me...
mona.........and thomas.........purple car................i want to see that......hehehhe
mona....get hot pink!!!!!hot pink hot pink hot pink hot pink
;) thats a lil too girly for my liking :D
and i'm soo jealous of liz's green bum!!!! i've been trying to get my 'skyline' to do that for awhile!! i've got the back panel and everything!!! i'll get it soon :P
Hey Mintie it was good to see you again I heard your car had a identity change ;)
Need to put the finishing touches on mine, waiting on cooler piping from japan, and then a bit more bits and pieces wire up AFMs, put back radiator, fluids etc and it'll be back!! Can't wait
LOL woot Phantom colour skylines, nah nah, dont do it, its gonna look crap.....besides, like who would drive a purple car *checks in the garage then hides LOL*.
Oh yeah, lol i did offer to scout........meh, its a ford, nobody looks twice at it, i had less change of getting pulled over then you guys did........after all, its stock ;)
Mintie, too bad you didnt cruise back with me and Damo ..... hahaha, you would have loved it :D
Hey Mona, next time you go to the creek, let me know, if ive changed my clutch by then, (and hopefully my gear box) ill be down.
good cruise guys, pitty the cops ***ed it up for us. and next time ill draw a map for everyone to follow. I kinda forget that most of u ppl dont know the area. Has anyone talked to the guy in the s15? i wanna know what happened to him.
good to go down to wisemans ferry, ive wanted to cheack that and the gorge out, not bad except nearly getting smashed in the rear going round one of the hairpins, but that guy is good at breaking, ill give im that much :-P
had anyone get any more photos? my car wasnt in them once *cry
hope everyone had a good time, just need to find away to make sure the cops dont stop up next time....
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
