Found bendix fade a bit too much, yes the ultimates or premiums or whatever they call em now.
Really liked "Green Stuff" by EBC and hear that u cant go past race brakes RB26's which are well priced too. I think both of those pads are semi organic.
My personal favourite is Endless SS-S, low dust, great initial bite, progressive and rated to 500deg C, so not likely to fade on the street. Oh, and they wont chew the ass out of your rotors either. I have also found project Mu are pretty good, not quite the same intial bite as endless, but otherwise on a par. I have also tried bendix and greenstuff, didnt think alot of them (personally), better than stock though, but dusty and seemed to wear rotors like there is no tomorrow.
your brakes will perform ALOT better with good pads than if you upgrade and use normal pads, (I went from stock SR20 brakes with project Mu pads to stock R32 brakes, and the SR20/project Mu combo pissed on the stock R32 setup) Once I fitted endless pads it was a different story though. Good brake pads are an excellent upgrade.
I would recommend getting the best you can afford, what price your life? cheap insurance and alot more fun driving the car.
I don't think it's your Ultimates that fade. I've never experienced fade in my Skyline and that's all I've used so far. I've been to about 10 track days and as everyone around my area and on this site can attest, I drive my car hard.
there are more factors to whether or not a brake pad will fade than just the pads, tyres, driving style, how tight the track is etc.
Your pads are obviously ok for how you use them, but not in Boostzor's case. I have know other people that have had fade on ultimates (so they told me), even though I didnt get it.
Alot of variables.
Yeh if the rotors are bigder they are going to dissapate more heat, so if they are thin they fade faster. When i had them they were on a jza70 and the rotors were about half way done. After 3 hard brakes u could feel it fading.
As steve said though, EBC ab RB chew rotors good. Too bad the endless are so expensive.
I would recomend do it youself or get one of your friends to do it Erik.
Just got back from the place in Bayswater (no name)......whata bunch of cowboys.....
They frucked one of my wheel nuts and their reasoning was " who did your wheels before" and that is after they takend them off , put them back on, and took the car to do the alignment....
.....and then they had decency to tell me its ware and tare..........dick****fiths.........:cheers:
All that: for them to tellme there is nothing wrong with my car.......
Well I get to the breakes now. I ask them why is one of my brake pads bent inside after I replaced them ....... and the guy tells me we are specialists but I don't know!!!
Whata???
So after spending so much money on different barke specialists that know fruck all...
Wheel alignment specialists......same......fruck all.....
So much for pro help.....
I have decided from now on, even with not much time these days I am doing it myself.....
Read the forums guys, ask for the manual if you need one, I have one, so does Paul and few more other people. DIY!!!
Boostzor, endless may be a bit pricey, but stack up well against others when you consider the money you save in not having to replace your rotors so often - more rotor = better brakes :rofl:
Abo Bob, bigger rotors can make a difference, both in thickness and diameter, as can the design. Take for example the 'roo paw' (or whatever its bloody called) design of DBA rotors - they spent alot of time and effort trying to improve the cooling efficiency of the rotor. Then you have the material that the rotor is made of which also makes a difference.
If you have aftermarket/upgraded rotors, there could definately be a difference.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
