that one pictured is a 90 series (twin turbo, non vvti 1J)...
hmm. i don't know much about it.
Anyways.....the same question but for the above car....how much are they going for in the market...the 90series?
Seing no-one has helped so far i'll be happy to lend a hand.
The car pictured is a JZX90 Mark II built from 1993-1996.
You CAN import and comply these however there are only 2 compliance plate holders for JZX series cars in Australia that i am aware of. A place in Brisbane and Auto wholesale in W.A.
Compliance right now is a total joke on these cars but they are seriously awesome, best 4 door sedan in their price range and even better than most twice, 3 times+ their price.
Good luck with it all, PM me or dojobi if you need any more help, we seem to be the resident JZX experts :stupid:
JZX 90's are avialable as I just got mine complied by Jim at JB WA and it is a magic car,
Contact him on Phone 0411 693256 as per DOTR's contact details or email him on [email protected]
Link to find who has what is http://raws.dotars.gov.au/rawswebpublic/rawpubmain.asp
Hey man do you know if he has 100 plates as well?
How much is he charging for compliance on 90's/100's?
Cheers, hopefully will be getting my 100 at the end of the year, need to save a bit more to get myself a manual 100 :flamed:
100 Plates are avialable off Frank from CAM and his contact number is on the link but when serious email me your personal address and I will pass it on as I see then once a week.
Have a look at the yard's any way as I am just trading my 90 in when I get a 100 due to the pricing is so good.
They have a manual 90, 60,000 klm, 18's, lowered, manual and TRD stickers by current trends and they only want $19,990 to get the cars on the road, it was also the test car is is straight as.
http://www.autowholesale.com.au/ has all the info.
Ali there's no one compliancing 90 series atm. We've got a client who's desperately trying to find a compliancer as well.
Either way, check the RAWS website to see when compliance is available and from who.
Whilst the 100's are nicer.. I reckon the 90's in many ways have much of the same qualities about them, and that much cheaper. They don't look that much different on the inside, and pretty much slightly older revision of the same engine...with a few power upgrades I couldn't imagine them being too different to drive.
I'd say they'd be a bit more different than you'd expect. They lost a turbo and added VVTi, so instead of max torque at 4800rpm in the JZX90, you get it at 2400rpm in the JZX100. I can see what you're saying though. The 90s are a very good cheap alternative.
JZX90's are an awesome car, but JZX100's are a step up again and they have come down A LOT in price so are worth it.
Interior in the 100 is much newer and has genuine carbon fibre trim standard :aroused: plus it looks much nicer.
As dojobi said, 1 less turbo, VVTi (exhaust), better suspension set-up and looks a shite load hotter!
Cant wait for mine! DRIFTT which company did you buy your car through in japan? Just need to start looking into finding an auction website that is decent who i can buy the car through in japan.
Will be good to see another 100 on the Perth roads so let us know when you get it, less than 10 JZX100's road registered in W.A. right now, which is good, keeps them rare :headspin:
I got my Mark II JZX90 through Mark Hocking from www.mytrading.org and Jim complyied it, I will give it till the end of the year then get a 100, I want to tinker with the 1JZ-GTE first and see what hp I can get on a budget.
I do love my 90 so it will have to be a Manual 100 to make me sell.
just b4 raws came in i paid $5000 to have my jzx90 complied under SEVS and that wasn't with tyres.
DRIFTT i got 226rwkw on 12psi out of my manual 90 with a few mods.
Power wise the mods are:
Power FC
Cat back exhaust
High flowed steel wheel turbos
Airpods
HKS side mount i/c
Blitz dual sbc
I am so pissed atm.... payed mid to high 20s for the car as it was and have poured probably easy 15k into it and i haven't had one enquiry about it yet. :( atm seems i'll be lucky to get even low 30s for it?
    • I did basically the same procedure on a ZF6HP but the reason to pull the valve body is to replace the seals between the valve body and the transmission which are notorious for leaking pressure with age causing poor shifting and burning out the clutches. If you just wanted to exchange all the fluid you should be able to undo one of the transmission cooler return lines to drain into a bucket while using the pressure filler to keep it topped off.
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
