Hey, thats my car
R31 GTS-R
RB25
Garret GT30 600HP turbo
Arias pistsons with GTR rods
PowerFC, 740cc injectors
Stock head
What exactly you wanna know?
And tim, when the turbos are rated, its in certain conditions i think...
Not sure how it all works though
to nismoid - what else like exhaust and other things that the engine has to make that sort of power ( how many revs will the engine take??? what is the redline? ,when does the boost come on hard?? and when you say gtr rods do you mean simply nissan factory rods??} , as i am very interested in a 31, can you e-mail or post sum pics for me , such as buid up pics , interior pics???? would be very greatful , fantastic clean 31 mate!!
redline is set to 7900rpm
its got a 3" exhaust, but im using an EXT so its venting atmo... i cant really plumb it in as the car suffers from not having 4" then.
i dont really have many pics of it actually.
Other than what other people have taken wherever...
They are just prepped GTR Rods.
It doesnt make that power all the time. That was just to see what happened when we put some good fuel into it and wound up the boost
There is a slight turbo mis match so it needs some decent fuel to get over detonation.
Im limited to 17psi normally, not 24 like that dyno run was on...
Only thing i need to change is the turbo exh wheel... but thats too much effort.
If i want that power jsut fuel it a bit for some fun
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
