Hi All,
Container has cleared.
BNR32 front cut.
300kph speedo, oil catch can, greddy profec b spec 11 brand new, seats (need retrim) strut brace, ARC airbox, ARC dual entry drag cooler (600x300x100), greddy hard pipe kit, brembo brakes on front, std on back with drilled rotors, hight and damper adjustable OHLINS sus, rear diff, bonnet with nismo lip, rear quarters. Blitz computer $10,000
1 x 91 180sx red top manual cut $4000.00
1 x 91 S13 red top drifter front cut $4200.00
1 95 180sx black top sr20 front cut $4500.00
1 x Galant VR4 fron cut with fmic and other goodies $3500.00
1 x 97 WRX front cut, excellent condition $3500.00
1 x levin 20v front cut $1950
1 x levin 4agze front cut $2450.00
BNR32 Veilside stainless steel exhaust front pipes back $1200.00
FD3S titanium exhaust $1500.00
Rays gram lights (gold) suit soarer supra. 17*8, excellent condition $1500.00
Tien HA with adjustable tops suit MR2GT $1000.00
other exhausts and bits and pieces.
Will post up pics soon. Not seperating cuts. Cuts come with brakes, diff and suspension.
Some panels available, please PM.
Cheers,
Ken
https://www.sau.com.au/forums/topic/74278-container-has-arrived/
  • Replies 91
i need r32 gtr parts
intercooler, radiator, condenser and fan, the plastic pipe that sit behind the intercooler connectting the plumback bov to the air intake, bumper reinforcement and maybe bumper if price is reasonable or a complete nose cut
pm asap
Any turbo-back exhaust systems?
Only cat back apart from the Veilside Evolution exhaust which is for a BNR32 and has front pipes back.
What are you after?
Ken
All PM's and emails replied.
Was after a cheap exhaust system for R33. What's your range of catbacks?
I have exhausts for:
R32 gtst
R32 gtr x 2
VR4 galant x 1
180sx x 2
S13 x 1
WRX x 1
FD3s titanium x 1
No 33's sorry, will get some next trip though.
Cheers,
Ken
have any r32 gtst aftermarket front bumpers?
or an r32 gtr front bumper?
any condition...
can PM me or email warren_clements AT hotmail.com
Sorry mate, not front bumpers for r32.
Next container maybe!
Cheers,
Ken
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
