GDay,
Just thought id ask all you gurus if a 600x300x105mm intercooler is a waste of time on an R33 GTR engine with forged internals, GT35 700hp turbo and upgraded everything else. Ive currently got a Hybrid 600x300x76mm cooler and i suspect this wont be enough to cope with about 320 - 350rwkw.
Ive got the opportunity to buy one for about $400 new so im just seeing what you guys think. Also, GCG in Sydney offer the 100mm intercoolers for $900 core only. Is this a bit steep? Any ideas where to get one for less than GCG's price?
Thanks,
Shaun.
it all comes down to the fundamentals of the design etc of the core as to wether an intercooler will work or not.
in saying that , it is a common misconception that bigger is better.
more often than not a greater thickness of the core is required when the face (surface area of the core) is small.
i am of the opinion that hybrid coolers suck , though im sure many upon many guys have them on cars producing 350 at the treads, which is their choice i geuss.
remember that just because a cooler "flows" 500cfm , doesnt mean it will work , the way a cooler should. i mean a peice of down pipe from ur gutter flows 500cfm but does it cool air.
if i was you , and judging by ur car and engine combo i wouldnt skimp in any area of its build up , go and buy a cooler and or a kit from www.are.com.au , i am biased towards that company as i have known the owner for a good 13-14 odd years now, and have seen numerous back to back tests and logging etc of various coolers, and also have one on my vl
in other words , 400$ for a new cooler , no way , go spend that 400 on alcohol and waste ur money on something u will enjoy :)
not sure why you went the Hybrid choice over the stock GTR cooler as they are good for the power figures you are aiming for anyway. The thing to remember is how well it cools the air passing through, not so much how much it can flow. Not 100% sure on this one, but if you go too big it creates more lag. Someone correct me if i am wrong.
Ill give the cheapo a miss, its too much of a risk.
yep good choice i have seen gtr's with reasonable gain from 250rwkw over the stock gtr cooler. a good 100mm cooler is the way to go not a cheapie. the jap branded ones are proven as well whihc cant hurt
meggala
I had an ARE bar and plate on my GTSt and was very impressed :(
Another recommendation for ARE!
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
