the air will be cooled LOWER THAN AMBEINT TEMP
Umm maybe u should go back to school, ambient temperature is the temperature of the air hitting the cooler, the cooler no matter how fast u drive your car through the "wind" will never be below ambient temperature, nor will ever equal ambient temperature, its not possible.
AS A SIMPLE ANSWER DONT POST SHIT AS FACTS WHEN U HAVE NO CLUE WHAT YOUR TALKING ABOUT.
  • Replies 45
:werd:
  • 3 weeks later...
i just read this thread for the first time, and my eyes are watering...
this thread is tops!
ROFLMAO
it's got to be a practical joke to sucker people in, surely!
hey, what if he put a nitrous spray on the intercooler? :lol
restrictions in your na setup is about as good as ceramic blades in your muggler tip. Every little bit of extra pipe and stuff will kiil performance. You can buy it if you want and wrap it in a towle and leave it under your bed.
Just don't put it on. It will slow you down and anyone who looks under your bonnet will think you are a pure ricer.
now for the constructive bit.... If you want to increase your performance. Get a pod and partition it off from the rest of the engine bay and run some of the springy pipe stuff from the bottom left hole in your front bumper. This way you will be getting air that doesn't pass through the radiator and AC condensor. You could also heat wrap the pipe that is in the rest of the engine bay to keep the temps down a bit more.
I hope this is useful info
    • No. GKTech arms have spherical bearings in them. No bushes. You will not need bushes for those arms. The sphericals are a bit of a maintenance nightmare. I have replaced all of mine several times in the 5 or so years I've had them, and I have the arms out regularly to clean and lube the balls. Worth the pain on an R32, because the standard arm design is trash. If you need the camber adjustment, there are other options (than the GKTech ones), although I would still lean towards and prefer the GKTech ones, even with the maintenance load of the sphericals. The caster adjustment is also highly valuable, allowing for setting the car up to drive straight. There are a million options for these, including the GKTech ones. I've had Tein rods on mine for 20 years and the balls are much less trouble in that location. Never given me a moment's pain. All positives, no negatives. I consider them compulsory.
    • Lol yeah I ordered the clips mentioned and as far as the amayama diagrams go i think thats all I'll need. Fogured id ask, sometimes people's first hand experience doesnt always match up to diagrams haha, i guess I'll wing it and worse comes to worse I'll just deal with it as I go
    • Thanks for all that information I appreciate it. To answer your questions: - Yep that's what I mean. These guys are professional painters to so I must be missing something. It's a bit hard to explain. - With the primer landing on clearcoat, I make sure that the surrounding clearcoat is scuffed to 240 grit as my epoxy primer says that I only need to sand the area to 240 grit. - Yeah so similar to the first question, assuming that the paint landed on the unscuffed clearcoat because I've seen that happen. - Yep I want to prep the surface in that order. Only reason because epoxy primer will protect it from rust and I need that atm with this crappy Sydney weather. I think I was worried about time, if I try to put the filler down but screw it up somehow and I don't have time to sand it off and reapply it then need to put primer later that it might start to rust again so I wanted to apply the primer as quick as possible to not deal with rust.  - I just deleted some answers, I just realised after watching a video and what you said about looking at the data sheet, that I need to read the data sheet on the specific filler I'm using. It's possible now that I put epoxy primer first was a waste of time and need to go to bare metal lol
    • I did. I went to a suspension guy and he told me because I don't have adjustable camber arms it's the reason why my car veers towards the left if I take my hands off the wheel but if I drive my other every day car and take my hands off the steering wheel it goes completely straight. I think it's common with Skyline's. In order to fix the problem, I likely need gktech camber arms then nismo bushes since I have poly bushes atm, then a wheel alignment after that. With my car if I take my hands off the steering wheel on a really bumpy road before stopping at a light I have to hold my steering wheel somewhat tight otherwise my car will legit just go completely in the other direction quite quickly and I'll slam into something lol instead of stopping straight. I Believe this YouTuber had the same issue and fixed it with gktech arms. At timestmap 6:05 he talks about how the car doesn't veer anymore after installing these arms.
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
