Yeah, I reckon its was some synthetic fluid that started to make mine leak
I have used the Castrol stuff in the red bottle this time, just by pure chance :P
Its the blokes down at ACBS that warned me away from Synthetic fluid. :P
I couldn't believe my chances though, just pick the master cyl up and mine completely pops, I drove home rev matching, switching off at traffic lights, in to first and crank the key. lol
I topped my old master cylinder up before my last Mallala day with synthetic/silicone fluid I was using in my brakes. A week later the seal started to leak. It was always a constant leak though, so I just kept topping it up with the Castrol stuff.
either way its fixed now, and has a resivior full of Castrol fluid!
Good effort to get home with no clutch. Poor ol' RB20 'box!
I asked the guy about my pedal bleeding off slowly, and he reckons it has to be the master cylinder, not the slave.
The slave will only leak fluid, or suck in air. Good way to tell which is stuffed (master or slave) is to block off the line and press the pedal. If it bleeds off its the master :P
He rekons 1 in 50 or so come brand new that are stuffed, so be aware, you can get a dud newie....
You had a dud newy did you not?
I learnt how to drive with no clutch in my first car. The TE Cortina's used to have a surclip to adjust the clutch cable, the damn things would always flick off leaving no clutch. :rofl:
Your clutch was bleeding off like mine.
Its farked, I'm telling you now.
I held my foot slightly on your clutch pedal and it went half way to the floor. :rofl:
Exactly what mine WAS doing.. Now it goes straight to the floor and makes nice squishy sounds.
Having a clutch that isn't bled correctly will cause you to crunch gears and not dissengage the clutch completely.
Clutch master done. :P
I didn't have time to fiddle with the pedal box today as I buggered around removing the little silly box that locate between the master and the slave cylinder.
I simply straightened the end section of the old metal piping then rebent it so that it mated up with the rubber hose that then runs to the slave cylinder.
The clutch seriously feels so much better now. Seriously I tell you. :D
I swear it feels lighter, more springy and much more progressive. Previously it was very bitey now it is much nicer to drive.
Ignore the rust mark on the floor pan. Thats an old heater that went pop under the inlet manifold. The camera really shows it up as orange. I should clean it up really.
  • 1 month later...
The forum change over broke a lot of links, using the WHITE PAGES would have got it for you, but here's the detials anyway:
ALL CLUTCH & BRAKE SERVICE PTY LTD
3 Pinn St St Marys 5042 (08) 8277 8122
Email [email protected]
Internet www.allclutchandbrake.com.au
Edited by Oosh
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
