Guest R34_GT-t
Hi,
Thank you everyone. :D
GTS-t, hehe....Sorry about the 1:18 thing. :)
Thanks GTS-t, I will post some pictures when I buy it. :(
Thanks Dino, I'm happy to see that someone I know is on here. :)
Thanks Timmy, XrSiSt and Shell. :)
Shell, I live in the Manchester area. Do you know of it?
Regards,
-Elliot
https://www.sau.com.au/forums/topic/7464-hi-everyone/#findComment-109911
Hey Elliot,
Be careful on these forums, you may get this wierd compulsion to sell your model skyline and buy a model 180sx instead.
(:uhh: it happens to them all:uhh: )
Oh, and stay away from the team westside threads.
https://www.sau.com.au/forums/topic/7464-hi-everyone/#findComment-109978
Originally posted by R34_GT-t
Thanks Timmy, XrSiSt and Shell. ;)
Well I've heard of it :) Don't know much about it though. I'd love to come over there one day! I've got a friend who lives in the Lakes District??? dunno where that is exactly either :D
oh and i've got another friend (an aussie) who is living in ireland atm
sooo keen to go visit him.....and the pubs :D
https://www.sau.com.au/forums/topic/7464-hi-everyone/#findComment-110550
Originally posted by Duncan
Hey Elliot,
Elliot, you must conform! There's no resisting!
Sell Skyline, buy 180, hang out with us westies
:devil2: :devil2: :devil2:
https://www.sau.com.au/forums/topic/7464-hi-everyone/#findComment-110556
Hi!
I have come from the GTR owners club UK forums. Minh asked a few of us to register a little while ago.
I would just like to say hello to everyone. :uh-huh:
Regards,
-Elliot
woohoo Thankyou for coming over and saying hi Elliot.
You and your UK members are always Welcome here!:D
https://www.sau.com.au/forums/topic/7464-hi-everyone/#findComment-110584
Hey Elliot,
We Arent Homosexuals!!!!!!!!!!!!!!!
What? you didnt mention anything about that? DOH! :D
https://www.sau.com.au/forums/topic/7464-hi-everyone/#findComment-110585
Hi,
Thank you Minh and Ryan. :D
Minh, No problem - I like to post on any Skyline forums. :uh-huh:
I don't know if any other GTR UK forum members have registered other than me and Dino (DCD). ;)
Regards,
-Elliot
Great. I might post a Link over here then for them.
Was speaking to some guy named Lee Pendlebury?
He has great pics on his website. Nice British Hotties playing twister. :D
https://www.sau.com.au/forums/topic/7464-hi-everyone/#findComment-110595
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
