hi all,
I'm going to be pulling my steering system apart this w/e and while I;m there i figured i may as well pull the radiator out and flush it (and as a bonus i'll have more room to work).
I noticed that the air con piping runs *through* the radiator to (well i think its called) the condensor. is there any way to take the radiator out without de-gassing the a/c system?
If i do have to de gas the system, how do i do it? what should i be careful of?
Any help appreciated :D
Thanks,
Michael :(
mine looks stock, but there is a gap (looks like it's by design) in the radiator code on the Drivers side, and one of the AC pipes run through that to the condensor. Seems like a stupid idea to me. I'll try and get a pic up tonight of what i'm talking about :P
i have 32gtst and all i had to do was drop the stone tray on the bottom of the chassis undo top and bottom radiator hoses the 2 mounts on the top of the radiator that goes to the front support bar and unclip the bottom of the fan shroud so it clears the rad fan and it should lift out untouching the condensor pipe work as this usually runs in a groove in the rad core design
hope it helps some
Yeap, radiator comes out pretty easy, just remember to slide it and the fan shroud on at the same time when you put it back, if you bolt the rad in then attempt to put the shroud back on you'll have a hell of a time clearing the fan and not bashing up your rad.
thanks lads...I'll have a look at mine tonight, but to be honest i don't know what they've done. Pulling a radiator out should be a simple thing, but doesn't seem so here :confused: I'll get some some pics up 2 nite. thanks for your comments.
The best way to remove the radiator is undo the 4 x 10mm nuts holding the fan on....remove the fan. Undo the 2 x 10mm bolts holding the brackets that hold the top of the radiator. Undo the top and bottom radiator hose clamps and remove hose from radiator. Disconnect green plug from drivers side of fan shroud. Slide radiator out from the top. Should take no longer than 10 minutes.
gah i feel like a damn fool :rolleyes: there's something for the aircon sitting in front f the radiator, which is why there's a pipe going into it.
The raditator should be a piece of piss.
Thanks for all the help guys :)
Shit that's right, i forgot you need to unbolt the fan, that's what i was thinking of whne blathering about shroud and rad in one piece, need the fan in there too! :rolleyes:
GTSt's must be different to GTR's.........with GTR's there's no need to remove the fan. GTR's have a removable 'section' at the bottom of the fan shroud which unclips and once that's taken off the radiator can be lifted out with the shroud attached and it clears the fan.
My GTSt same as SteveL s GTR. 2 mounting bolts on top , drain water, remove one end of hoses, unplug wiring connector, lift out [ about 3 minutes. no removal of splash guard , fan, etc., etc. They must have kept changing their minds on the assembly line.
Takes longer to drain the water, than anything else.
I think you're getting confused with the air-con heat exchanger, it sits directly in front of the radiator and looks a lot like it, I killed my rad last weekand pulled it out (found that half of teh shroud that unclips down the bottom) and it really is a simple exercise to remove.
Now i need to find a replacement radiator, i'd rather a new one, but might have to settle for second hand.
yeah that's exactly what i was confusing it with :Oops:
At a glance it all looked like one part, i pulled my radiator out last week (unclipped the lower part of the shroud, removed the hoses and upper mounts) and had no hassles :cheers:
What's gone wrong with your radiator? leaking?
Rubber mount up top had perished, I accelerated hard, radiator fell on to the fan and crunch! On stuffed rad, called Nissan and they wanted $962 for a new one, I can't see much point in a 2nd hand one, so i rang around some more and found and aftermarket one for $359 which is far more reasonable. Gotta fix that mount too so it doesn't happen again.
Just went to pick it up and it was the wrong one, guy did some more ringing around and found the right one for $439, but there's a question makr over availability. Some Nissan diesel has the same top and bottom tanks but the core is too tall, might be able to make some Franken-Rad, just waiting for a call back.
Just thru a local radiator mob, Burton Radiators, pretty helpful so far but we'll see how it goes.
picked up my new r32 radiator last week for $352 brand new......the brand was KOYO i think.....looks the same as the nissan one, it works.
Yeah Koyo are supposed to be pretty much atleast as good as the originals.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
