Underneath the dash just on top of the clutch there is a bracket that holds the clutch. When i push the clutch in you can actually see it moving is this a big problem? Can somebody plz look and see if there bracket moves or is mine screwed? And whats that bracket called, i need to source a new one and is it hard to change do i need to remove the whole dash? Im told beacuase I have a heavy duty clutch thats why it came loose to much stress. And would anybody have an average price on what its worth.
Same here. I have a heavy twin plate and it ended up mangling the bracket so far the clutch pedal sat on the fire wall and I had to pull it up with my foot first to press the clutch in.
Apparently a common prob with heavy pedal effort clutches.
Not sure with your car but with the HR31 its made from thin metal with just a few spot welds here and there. Got another one out of a Pintara and it was welded up properley with extra plate steel reinforcement. I would just get one in good nick from a wrecker and reinforce it as it will only happen again.
The dash didnt "have" to come out but it was of those " get out you f@cking little c@nt of a thing" type of jobs.
It's a common occurance, I have broken the one in the R32GTST race car. It has an OS Giken twin plate in it, so not excessively heavy. Broke through the spot welds. The first sign was long pedal, needed to be depressed further to declutch. It just got slowly worse until no clutch.
Not only is it hard to get out, it is efen uncomfortable lying upside down, with the steering wheel in your crutch, the seat base in your crack, your feet on the head rest and your head under the brake pedal. Talk about rush of blood to the brain.....:headspin:
yer mine snapped as i pulled into work....luckily.
Looking back i replaced the clutch master cylinder, and the pedal was squeeking inside the car. Thought nothing of it. Clutch then seemed to play up now and then in car parks, thought nothing of it. Then i remember some clunky gearchanges, thought it was the gb cos it needs bearings.
Then as i pulled into work, i heard a small pop. Then 2 seconds later, it popped again and the clutch went to the floor. :D
Now i got a new clutch pedal box sitting here ready to go in. I was going to make a new pedal box out of some thicker 3 or 5mm steel, but ill just reinforce the new pedal box with steel around the 4 spot welds that hold it together !!!
No. Two bolts in engine bay on Clutch master cylinder. Then one looking straight up from the clutch pedal. You need a pillow or something on to lie on, then look up where the clutch pedal is..........SK described it exactly :
Not only is it hard to get out, it is even uncomfortable lying upside down, with the steering wheel in your crutch, the seat base in your crack, your feet on the head rest and your head under the brake pedal. Talk about rush of blood to the brain.....
I'll tell you as well what makes the whole process a heap easier ...
If you don't use the air vent near the drivers door much, just rip out the tube underneath the steering rack (or maybe it goes over, I can't remember as I pulled it out so long ago).
It makes the whole procedure so much easier as you can get to the nut on the pedal box with a socket and an extension :(
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
