vice city rocks, except mine bloody stuffed up at like 12% and stopped giving me missions, so i had to start from the beginning again coz i kept overwriting my save file ;)
the music is the best
leave it on emotion 99.3 and listen to the 80s hits :D
billie jeeeeean :mad:
love the weapons
the chainsaw, samurai sword, meat cleaver
and the bikessssss :D
https://www.sau.com.au/forums/topic/7484-vice-city/#findComment-114817
Yeah the bikes rock... for me it's a fight between the 600 roadie and the scooter :mad:
Have any of you guys got the tank (Rhino)? It's farking brilliant, you can go for ages with a really high wanted level and the cops can't get you unless you stop and they make it to the door... carnage ;) And the vigilante missions are really easy with the tank... aim in the general direction and let off a shell :D
https://www.sau.com.au/forums/topic/7484-vice-city/#findComment-114972
good question, i own 4 properties in the game atm, but havent found 1 on the other island that i can buy yet. I love the game, but various reall life things(like work, gf) keep me from playing it much.. its so sweet though i try squeezing in asmuch as i can.
Love the bikes(cbr600, dirt bike, hog and scooter) i try seeing how far i can wheelie for and then stopiee haha.
Also 1 of my fav guns has to be the colt python.. cant buy it so i jsut kill that shop owner then grab his colt, waite for respawn kill grab etc.. unstopable once u have it and some ammo
and hows about the corvette wonnabe's with the scoop and butterflies that actually open! bling.gif
https://www.sau.com.au/forums/topic/7484-vice-city/#findComment-146054
  • 4 weeks later...
  • 4 months later...
Guest AzNBoI133
OK for all u GTA vice city newbs LOL u gotta get the mansion on starfish island first before u can even enter or buy things on hte second island i think... its part of the missions just do em in order they are given to u i think u can buy the car show room, boat yard, ice cream shop, and....... ummm kofman kabs on second island i recomend the big hotel thing in the second island near stadium it gives u a free helicopter
https://www.sau.com.au/forums/topic/7484-vice-city/#findComment-463548
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
