i have recently written-off my R34 GTT after owning it for only 6mths. It wasnt insured either so I am gathering as much cash as possible to compensate for the loss. The rear to middle section of the car is damaged, so most parts from the front are all salvaged. If theres any parts u need jus PM me for details and il drop u sum pics. I have most bolt on parts such as an intercooler kit, aftermarket airfilter, T04 turbo, also GReddy gauges, boostcontroller, turbo timer etc
cheers
https://www.sau.com.au/forums/topic/74849-wrecked-r34-gtt-all-parts-forsale/
location would be helpfull
And maybe if you list some prices for some easy sales like engine/box, Mods, rims, lights, etc.
Good luck man, I'm going through the same thing (stacked the front of my r32 a while ago), i got a engine, some interior, rear panels, and all the glass left. The rest is gone.
P.S. organise some prices to see what you can aim to get back from it. it helps
OK.....first question was it a manual ??
if yes......then ill DEFINETLY buy the power steering pump off you.
PM me and ill negotiate a price with you....mine is currently leaking....had it reconditioned TWICE.
Also If you had xenon lights ill buy them too....depends how much you want for it of course :rolleyes:
was the T04 turbo a bolt in replacement ????
I am interested intercooler and turbo and boost controller.
Also want to sell me your seats and steering wheel?
What boost can the turbo run, and will it bolt onto the RB25det standard flange?
custom dump and frontpipe?
PM me the details.
Thanks
If u r genuinely interestd pls take the time to pm me, caus i realy dont want to be goin back and forth with ppl tat D!@# around on this thread (ie "do u hav this? do u hav that?") the thread gets flooded and nothing eventuates. il pm u prices and details of the part or if the part is sold. And if u wan pics jus pm me ur email.
Replys listed have been pm'd or emailed
thanks
Sold - most interior incl. all electronic aftermarket accessories, seats, dash/ damaged bodyshell/ turbo/ bonnet/ driver glass window
Still have front exterior parts - headlights $750 delivered/ Mirrors $180 delivered/ frontbumper without blinkers $150 delivered/ all indicators $15 each deliverd/ 2mths old intercooler kit $900 deliverd/ basic engine mods BOV $160 delivered, airfilter $60 deliverd, might separate engine parts depending, jus let me kno which part.
............Pls Pm me thanks................
how much would you want to chop the front off (if manual) n sell it to me as a front cut basicaly.. all panels and all other shit can be taken off basicaly.. i need engine, gearbox, wiring harness, computer, n the usual shit so i can drop her in my sil to replace the dead rb20 :D
Warrick
email me at [email protected] or pm me either way
cheers
hey mate, do you still have the standard boost gauge for sale?
If not how much you looking for the GReddy boost gauge? (are they 52mm?)
and how much for the boost controller? (what type is it)
where abouts are you located?
THANKS :D
Sold - all interior sold/ damaged bodyshell/ turbo/ bonnet/ driver glass window
Available-
2mths old intercooler kit (600x300x100)- as new $900 deliverd
BOV $160 delivered
All parts negotiable
Pics also available to email addresses provided
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
