fitting new deck in r33
Guest GR33DyMANGO
hi guys. ive got a 96 r33 series 2. how on earth do i get the old stereo decks out of the dash? seems like a big job!
there are 2 kenwood decks in the car at the moment. ie the normal cd player and a spectrum analyser/equalizer/look good screen:) or what ever its called.
i want to put in my pioneer oel deck and possibly attempt to hook it upto the spectrum analyser/equilizer deck??? hmmm.. can this be done?? they are 2 different brands.
also i need to take out the speakers in the doors to insert new splits. also, where do u guys put the crossovers. i really want to just hide them somewhere.. maybe just behind the deck??
https://www.sau.com.au/forums/topic/7494-fitting-new-deck-in-r33/
to take the stereo out,
1) unscrew your gear knob then
2) take off the surrounding plastic panel around the gear shifter (they clipped in).
3)then take off the plastic surrounding that goes under the speedo all the way till around the stereo.
4)unscrew the stereo put the new one in. and party away.
not sure though about the equiliser connection see if there is a cable coming out of it that can be put in the stereo
As Skyline33 said, start with the gear knob, pull out your ash tray and start unscrewing any screw you see. Everything else is held by clips.
Really easy to do - one of the easiest I've ever done.
As for equaliser, depends on how it connects to the deck - if it is by RCA or speaker inputs, then can be done. If is a special plug (ie Kenwood exclusive) then you won't be able to - I'd say this is more likely to be the case.
Splits - a couple of suggestions, under the carpet near where the kick panels are - I have a phone kit in my car and I put the control unit under the carpet about where the right passenger foot would rest. This unit is about the size of one crossover, but I'm sure you could fit another in there.
You might also be able to mount them under the dash (maybe tape to the steering column).
You will probably just have to have a play around to see where you can sit them whilst avoiding making any holes.
Hope this helps. Maybe try contacting a car audio specialist for some ideas.
Does the standard stereo come with splits? I notice a mesh thingo on the window pillar..i assume its the tweeter for the split??
I'm stuck on the standard tape player at the mo, getting impatient for good sound once again after only a few days of the radio :)
What about wiring? is it a standard DIN connection for the stereo or do you have to use a wiring harness or the like? Would be nice if its just plug and play.
Splits weren't standard on my car when I got it. I just had crappy stock 6's in the doors.
You may be able to make wiring it easier by getting a harness and soldering these wires to the harness supplied with your deck- I think Aerpro make one for the R33. But I'm pretty sure all you have to do is put connectors on each of the wires out of the deck to match up with the loom (I had an aftermarket deck so I can't be sure about stock). The harness might juts make things a bit neater.
Wiring for decks is really not that hard to do once you have a basic idea of how to crimp, cut wires and joining corrct wires together. The hardest bit is mounting the things and in most Nissans and Toyota's it is very easy!! :uh-huh:
Yeah, its not too hard to get the hang of. This will be my third install in a car, although the other 2 were transfers.. Even if you have to do it only once every 2 years its a pain in the butt. Just wondering as I have yet to dismantle the dash (thanx for the advice on how to do that as well guys).
I was able to get my HU out without any trouble at all.
I tried the other day to get it back in but with the metal mount things I can't see how its possible to get it back in through the dash.
I'm going to the track day tommorow so if no one can help me before then i'll take my screw driver along and ask someone to help me. (its a double din japanese pioneer).
Thanks for any help.
Mark
Guest GR33DyMANGO
hey guys thanks heaps for all your help :)
red sky: the antenna problem was my friend jimi:) hey hows your car going? i got mine registered today:)
another query.. how on earth do i get the side speakers out? and how do i take the rear seat out so can make a new parcel shelf?
ta
justin:)
To get your rear seat out Mr Mango there are two screws near the bottom of the seat. You then can yank the seat up quite hard near where you took the screws out. To get the upper part of the seat out I think you lift it up because its held on by three hooks - you also have to get it around the seat belts.
Mark
Good news Gr33dy that you got it registered - you gotta be happy
Its doing well - gotta get the suspension sorted out and a new stereo installed then I'll be happier. Then the sideskirts fitted and bumpers repainted then done for now. Most of the basic mods are already done like exhaust, pod, etc
How's yours doing?
Cheers Al
Did my install in about an hour. As you guys pointed out, very easy job! Just remove the facia surround and a few screws and it pops out. You need to lever the bit over the steering wheel fairly carefully as it needs to bend a bit to get the right airduct out of the dash.
Most difficult part is just ensuring that nothing gets scratched moving everything around. Through trial and error worked out most of the stereo wiring for the R33 as well to connect up my new unit.. i'll post it soon.
btw: yes, my stereo does have splits as standard I worked out.. obviously some do. Standard speakers aren't much chop though... new unit didn't make massive difference to sound quality.
Guest GR33DyMANGO
im finally gonna get round to installing my stereo tomorrow. the deck my car came with wont play burnt cds so ive been listening to cds that are about 10 years old as my entire cd collection is burnt:)
red sky: yer the cars going sweet except for this really wierd sound emitting from the dash????? it sounds like a small bit of tin flustering in the wind.... really wierd...... so i'll have to work that out.
hey predator, if you could post that wiring info in the next few days that would be a great help... doing an install real soon and don't want to blow too many fuses with the trial and error technique (and yes i'm too cheap to buy one of those little "glows if there's power" gizmos)
Hey Beeble,
I'm off for the weekend... but just quickly...
Green + black/yellow - L Rear
Orange + Puple/black - R Rear
Brown + black/white - L Front
Blue + black/red - R Front
Blue/Yellow (stripey) - Accessories (+12v)
Red/White - +12v from battery
The above have fuse like things on them so they are fairly obvious.
The other one is the aerial up/down. May have mixed the front speakers but you can work it out thru trial and error. As long as you don't stuff the power wires, and connect the ground wire first, everything else won't blow it up so you can trial and error the rest for the speakers.
Hope that helps.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
