6 X r34 gtr injectors $350
2x bov's standard $150firm for both
2 x hks airfilters $120 firm for both
standard gtr manifolds $200
standard gtr turbos 1 is good $300 and other will need seals replaced $100
standard actuaters of gtr accepting offers......
standard piping for for the standard turbos $150
standard plump back pipe for standard bov's which sits under the fmic $50
standard ecu $150
3" cat back exhaust which flares into 4" just before the back tyres and sorry no cat $100
also have some 17" tyres 17 X 45X 235 $70 each between 70 and 80%tread left on them
also have some 16's not sure of the exact sizes coz i cant remember if your after any 16 s just ask and ill see if i have them or not
thats all i can think of at the moment
please not these parts are all off r 32 gtr except for the 16' tyres
cheers damo
https://www.sau.com.au/forums/topic/75052-std-r32-gtr-parts/
