Jarrod - not at all. They will just tell you which flags mean what beforehand and give you a colored sheet incase you forget. Its pretty easy however.
Last time at Winton I did it in the afternoon and didnt even have to wave a flag. Just joined in the amuzing conversations on the cb radio's and took lots of pictures from the best seats in the house!
Guys,
The WRX Club are still seeking people to help out with Flagging at Sandown for June 12th.
Anyone that would be interested in helping out please contact Hung at:
[email protected]
The man said email guys!!!!
Anyway i coundn't afford to run so i've email them. If they need me or not, still i see you guys on the day.
Guest
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
