I was looking for tyres for my gtr and i came across these .
Toyo proxes T1R's 275x35x18's 99Y .
They are the top of the line silica compound and i've been told very grippy tyres .
Retail price for these around $600 per corner .
If i can get enough people to buy 20 tyres , i can get them for the bargain price of $340 each , thats well bellow wholesale !
At that price we have to do our own fitting and balancing ( around $10 per tyre ).
Don't ask me for different sizes thats the only size at that price , they are good for gtr's all around or gts's for the rear .
Anyone interested please let me know , i already have 8 on order so i need 12 more for this to go ahead .
Pick up in Sydney .
There is a link to the tyre http://www.toyo.com.au/
https://www.sau.com.au/forums/topic/75254-tyres/
Anyone driven on them? How do they go in the dry/wet?
275 is a bit fat to put on 9" wide rims isn't it? Are you running 9.5" rims wrxhoon?
The toyo T1R in 275 is actually only 4mm wider than a T1R in 265. From memory, the 275s are only 271mm...some 265s in other brands are wider than that.
https://www.sau.com.au/forums/topic/75254-tyres/#findComment-1394884
I have stock rims 18x9 . The 275x35x18 T1Rs are only 4 mm wider than 265's . ( 271 mm and 267 for the 265's )
If you go to their website , the recomended rim width is 9"-11".
At $340 they are very cheap .
https://www.sau.com.au/forums/topic/75254-tyres/#findComment-1395280
These are excellent tyres. I'm running 255/40/17's on my GTST at the rear and I paid about $340 each for them so if you can get that size at that price, it's an absolute steal cause I certainly didn't pay retail for mine! Good luck with group buy, but excellent tyre. Very grippy.
https://www.sau.com.au/forums/topic/75254-tyres/#findComment-1397631
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
