89 GTR for sale
- NEW Garrett R34 Ball Bearing Turbos
- NEW cushioned button clutch
- Top secret ECU & 550cc injectors upgrade
- standard factory condition
- No accident repair history
- mechanically perfect - Any test welcome!
- HKS turbo timmer
- K&N Filters
- full exhaust 3.5"
- 6 months rego
Price drop $22k.
contact :0405 584 881
https://www.sau.com.au/forums/topic/75263-gtr-r32-must-sell/
89 GTR for sale
- NEW Garrett Ball Bearing Turbos
- No accident history
- HKS turbo timmer
- K&N Filters
- catback exhaust 3.5"
- RWC & 9months rego
$23500 neg for serious buyer.
must sell - contact :0405 584 881
Its very umm clean...
Would you swap for an R33 S1 + Cash?
Can you tell me more about the car. Has it been on the dyno? What kms do you get out of a tank? What kms are on it? Other mods and are there any interior pics? Reason for selling so soon? Thanks mate
Car has been on dyno - made 171awkw- boost restrictor still in place!. Since then I have fitted a highflow cat, K&N Filter, new s/s highflow front pipes (3"), 550cc injectors , top secret ecu.
Don't have any pics of Interior - but its perfect apart from the driver seat starting to wear out.
Any chance of getting some interior/engine bay pics?
Have you done a compression test?
Seen this 1 advertised on Carsales for awhile now, also seen some discussion about it on other forums, looks neat!
Engine bay/interior looks totally stock standard - don't have pics yet.
Have not had a compression test, but dyno results indicate that everything is ok!
I drive the car everyday!
If ur serious pm me or contact my mob for inspection!
  • 5 weeks later...
  • 1 month later...
GTR in Excellent condition. New Garrett R34 Twin Ball Bearing Turbos, New exedy cushioned button clutch, new denso 550cc injectors. All upgrades performed here in Aus early 2005. Nismo front bar, bridgestone tyres. 4WD, 4WS, 3-point security system, No accident repair history.
Recently serviced new fluids(coolant/oil/g/box, clutch/brake)
$21,000 ono
Melb.
For further info contact Vlad : 0405 584 881
Responding to phone calls ONLY!
  • 3 weeks later...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
