As long as your still running a pull type clutch in your GTR it will fit straight in.
Where did you get your exedy clutch? I thought they were only around 2500lb of pressure on the exedys.... Regardless if DIRTgarage are running it on thier car (450rwkw+) then it should be fine in yours yeah?
I'm assuming your running a GTR?
All clutches aren't built the same(hence why Jim gets such a good rep around here) if you want a multi plate, go for it - but i think the proof is right there - DIRTgarage running the same clutch (as a drag car) with 450rwkw+
I think Paul and Stacey may be able to expand on this a little :) But they aren't selling this to make a profit, they just have it left over.
DIRTgarage is Paul&Stacey (who are selling this clutch) PM them, or wait till they reply to this thread. Sorry no number for them :D
Not sure about the oil pump - find the part number and get your local nissan dealer to order you one in?
Yes im running a R33 GTR. Do u have the number from DIRT- garage ?
One last question, would u know where i can get a n1 oil pump from and how much?
Thanx.
I put Paul and Stace from DIRTgarage aka two.06L on to Jim Berry Race Clutch to try one of his race clutches. They were looking at getting a twin or triple plate which cost big $$$ as you know. Quite simply its superb and the best value for money clutch you will ever buy anywhere. Beauty of this clutch is its a single plate, some might scoff and say a single plate can't handle high hp, well normally no but a Jim Berry single plate GTR race clutch can. Its very streetable, no rattle like multi-plate clutches and can handle high rev clutch dumps all day everyday. With two.o6L now making 411awkw and 467rwkw and now with the Mickey Thompson ET's it requires an 8000rpm+ clutch dump to get off the line without bogging down and if you've seen the 1.65 60 foot times there is not even a hint of slip and like Paul says, 2yrs of racing and its still superb.
Simply the best clutch out there as for max hp thats unknown at this stage but rest assured it can handle very high hp.
Either contact Paul/Stace or me from DIRTgarage via pm and leave your number one of us will call you.
Cheers
Thanx.
Nissan , about $500
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
