It's all right for tonight, cruising in a corvette and feeling alright!
haha, well considering the engine is being pulled it wont be available. Damn baffled sumps! :D. Anyway, CES fitted mine and just used 2 normal 2.5" cats and tilted them sideways to fit, not sure if this picture shows it properly though. The bar only melts when I go to the track, cause it is such a big heavy exhaust, when doing serious corners it must press against the side of the gap for the zaust. You mustn't be driving hard enough eh?? hehe, jokes :Pimp2:
  • Replies 100
haha, well considering the engine is being pulled it wont be available. Damn baffled sumps! :). Anyway, CES fitted mine and just used 2 normal 2.5" cats and tilted them sideways to fit, not sure if this picture shows it properly though. The bar only melts when I go to the track, cause it is such a big heavy exhaust, when doing serious corners it must press against the side of the gap for the zaust. You mustn't be driving hard enough eh?? hehe, jokes :Pimp2:
LoL, i drive it hard.. jus never had a chance to take it on the tracks yet.. Have you dynoed it after you put on the zaust? i got 215kw@all4s with just the zaust and pods (stock boost). I thank the zaust for the good power. Also what dump pipes do u have? Im still using the stock dumps.
I got 197awkw on the mercury motorsport dyno with just the exhaust and a nismo panel filter(stock boost also). Still got the stock dumps for the minute, but one of the things going in atm is a pair of hks dumps to finish the exhaust. I am interested to see what, if any, difference they make.
the wastegate sound will be louder i know that much. it should also give it a diffrent tone. those stock dumps are shocking, i cant belive i had stock dumps at 300awkw. when they pulled the stock dumps off i couldnt belive how badly they reduce in size :O
CES make there own dumps, thats where i got mine from n e way. just make sure u get the HPC coated ones.
i think they were around $900
give them a call.
check out there website
http://www.cesracing.com.au/
the hks dumps actully go down in size at the bottom of the pipe which is STUPID !!! why o why would they do that ??? doesnt make sence,
thats why i went the CES ones they were bigger than the HKS DUMPS and arrived the same day i ordered them :O
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
