Well not actually the engine itself.
Last night I went to adjust the boost a little on my little boost controller (the one mark sells on here) and split the hose.
Thought no worries. Replaced the hose but when I took the car for a drive it made a weird "whurling" type noise with any ammount of boost pressure. To me sorta sounds like a air leak but not sure< is that what noise it would make if a cooler hose blew off?
Even with the hose removed it still makes the same noise.
I thought I might have tore a little hole in one of the pipes from the afm to the turbos but they all seem ok, removed the clamps etc and checked under there.
Anyone know what it could be?
https://www.sau.com.au/forums/topic/75736-rb26-making-weird-noise/
argghhh. hope its not one of the gaskets.
car still runs fine, it will make boost but seems to be down a little bit on power. the noise also seems to go away after around 3000rpm, sort of when the turbos really start spooling.
most likely one of the turbo gaskets? would it be a head gasket? what are the symptoms of that?
it sounds like a ghost comin from my engine bay. can really only hear it from 2000-3000 revs under load, even coming off load from about 5000revs you cant hear it again till it comes down to 3000 or so again.
Im guessing its one of the turbo gaskets? maybe to the manifold. Surly someone knows what it is. Car still drives fine and comes on boost fine.
Ive had something very similar in my R32, ended up being a gasket just off the turbo..
Its quite common for the bolts on the "Twin Turbo" pipe to work loose, particularly for the rear turbo, and the gasket to blow. Unfortunately they are not a standard gasket so you have to get them from Nissan AFAIK (or as I did, make them).
I currently have a high-pitched leak somewhere (plus backfiring) and I am pretty sure its the same gasket. :(
Lucien.
thanks champs, ill swap them next week and see how it goes. I hope its just one of them so the turbos dont have to come out.
Can I buy just those 4 gaskets or do I have to buy the whole set from nissan?
also will the leak cause any damage or is it still ok to go boosting it a little for normal driving?
Its three gaskets, and Nissan doesn't do turbo gasket sets anymore, so you just order in the three.
Before you do though, better to check that's what is actually causing the problem. The recommendation I have seen lately is to mix up some detergent with water and put it in a spray bottle. Spray all the possible connections, fiddle with the throttle to rev it a bit, and look for the bubbles.
Hard to say if it will cause any damage without knowing exactly what/where it is. At a guess, probably not, but it will throw the mixtures out as air is escaping.
LW.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
