Thanks again.  I'm just worried that some won't be acring at idle yet at 9psi they may start to.
Or do you think you would see a small amount of arcing at idle to show if one is had it or not...
i cant answer that one for sure! but the arcing at idle is only a little bit anyway as in the car you can barely feel it its only a very slight miss, even when watching the motor as it does that you can only hear it miss a little bit.
if you see a few doing it u know that u might as well replace them all, if u only see one doing it its probably worth swapping that one for a good coil from somewhere to see if that was the only problematic one. or u could go on swapping your coils for good coils once by one to see which ones are stuffed but by the method i told u u can see which ones are really stuffed straight away.
  • Replies 49
Hey Siks. When you run the without that top cover over the coils did you find it necessary to use spacers/nuts to space out the ignitior module (located towards back off engine. Or does it not matter that the bolts will go in another 10-15mm further due to lack of the raised section on the plastic piece.
Thanks
hey i have a series 2 so there is no ignitor module that function is built into the coil..
i understand what your saying, and im pretty sure that friend who have left the cover off used the original bolts to hold it down, have u tried? if not just try the worst that can happen is that you just wont be able to screw them in anymore and the module wont be secure..
I have the cover off and I can't see any sparks at idle or when I rev it.
Does this mean the coils are fine?
Under boost there is a lot more pressure on them. Shuld I not give the coils the all clear yet??? As they may be leaking under boost and high load??
Maybe I should warm up the car more...
Thanks
Still no spark. Is it possible that I am hitting the boost cut at around 9.5-10psi??
I have an R34 intercooler so I guess that may mean I'm getting a little more airflow for the given pressure.
Also have 3" exhaust but that's it.
I thought guys with front mounts were running up to 12psi on standard ecu without boost cut (from excessive airflow)
i seriously doubt u are hitting boost cut..
are u sure u were somewhere really dark as the sparks are only small they are not bright at all
even if no sparks they might be stuffed just not that bad.
only thing to do now is swap the coils with someone else who has no problem, this will make the answer to whether it is the coils for sure. .. so go and pull some out of a friends car :D
u can actually remove the coil cover without removing the piping, i discovered this while being impatient/lazy one night :D if u just undo all the bolts u can slide it out as long as you remove the mount on the rear of the cover.
u might have to bend it a bit to avoid scratching it :(
  • 3 weeks later...
Hey siks - when you saw thos e coils arcing was it only very small.
It has to be very dark and I can only see a tiny bit of light near the efge of about 3-4 coil packs.
Not really a shotting spark. more like very faint light every know and then.
anyone?
Yes, it depends on where the spark is jumping. If it is down the inside of the coil to the plug body, then it is hard to see. If it is from the outside of the coil to the cylinder head it is very bright and easy to see. :)
Mine appear to be arcing to the metal body around the coil packs (i.e. the part that you put the screws through) - It is only very faint - is this still something that could be causing the hesitation as I rev the car out?
It is on about 4 coils. It isn't a shooting arc I can just see some light every couple of seconds at each coil. Gapping the plugs to 0.8mm from 1mm hasn't helped at all.
The mechanic reckoned I should gap them to 0.6 - if this fixes it the n you know it is coil related. I'm thinking of borrowing a friends to check i.e. coil packs..
Problem mainly happens on cold night when air is a bit more dense - but occurs at about 8psi.
Mine appear to be arcing to the metal body around the coil packs (i.e. the part that you put the scres through) - I t is only very faint - is this still something that could be causing the hesitation as I rev the car out.  It is on about 4 coils.  It isn't a shooting arc I can just see some light every couple of seconds at each coil.
That would seem to indicate that the coil isn't earthed properly, are the bolts tight? :)
The bolts are pretty tight I think. The light is coming from the plastic body to the metal frame of the coil. I'll attach the pic here so you cans see where the burn marks are happening.
I didnt think this could be earthing prob?? Does that metal frame earth the coils?
Ok - so you think even though very faint light the coil packs are still cactus. I picked up some others to try that don't have the burn marks.
The wierd thing is you can see the light if very dark on about 4 coils. If you then rev it, while you are revving there is no light evident, however once you then back off the light (leaking) is worse.
Does this mean under acceleration they probably aren't leaking - or once you add boost they would.
On the dyno the guy couldnt find them leaking though I dont think he ran it for more than 5-10minutes and wasnt that dark.
Replaced with ones that are known to work at 19psi
STILL the same.
On these ones I can still see small amounts of light if dark! Not an arc but lights up lightly around the body.
The coils have no burn marks on the side...and actually my ones look good aswell.
Im thinking powerfc time!!
Maybe I am getting rich and retard at just over 8psi...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
