I have a Pro series power FC and the hand controller for sale. Its was in my car for bout a year. Still in perfect working order. Was taken out cos of the sale of my car.
After $1000 + post
PM with any questions
And is this the model that doesn't require the afm?
no that's DJETRO. Pro has launch control (stationary rev limit) and ign cut rev limit (instead of fuel cat).
as above, what model car?
ah, everything becomes clear. Thanks
Is there any other different between the Pro and the normal model ?
I am planing to set up my car to track racing. Is it advisable to use the PRo model?
Does the DJETRO have the above as well as being able to remove the airflow meter ?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
