Only used for 1 month
Anodised blue
Direct blot on to R33
Adjustable between plumb back and atmo
Perfect condition
RRP $529
Sell $350
0404 075 314
Details
http://www.gfb.com.au/index.php?parentid=p...tion=stealth_fx
https://www.sau.com.au/forums/topic/75950-gfb-stealth-blow-off-valve-suit-r33/
i hate to sound stupid
but i totally am a bit clueless with blow off valves.
Does stealth mean that it is silent
or does it mean that its got that race/stealth adjustment to adjust how much of a showpony you feel like on the day?
If it is not silent what sort of sound does it make?
In "stealth" mode the valve is full plumb back just like the factory valve. No extra noise than factory.
When you adjust the top knob you can start to bleed air to atmo which makes the noise.
When fully open, the plumb back is fully closed making the valve a atmo type which attracts plenty of attention or you can have a mixture of both to get the perfered sound you want with less nosie.
You can also adjust the spring pressure to make a flutter sound.
Hope that explains it.
The reason I am selling it is because I removed all the aftermarket parts off my car to sell it.
:confused:  Where is the OEM BOV located in the car?  :Oops:
It is on top of the engine, mounted on the side of the crossover inlet pipe
Takes about 10 min to install. 2 bolts and 2 hose clamps.
Very good and cheap price guys. Snap it up quick. These BOV's are known as the most well designed and versitile BOV's on the market, as said you can adjust sound to however you feel like and you can also get another trumpet if you want another sound. :)
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
