on my RB20DET as I was removing a few of the camshaft caps and the bolts were very tight in the cap, i.e. I couldn't pull them out, so I had to try and remove them so I could clean the shank up other wise torque settings would have been very wrong :wack: (so it was not the tread that was tight, but the shank welded to the inside of the cap)
I soaked the bolts for about 5 days with wd40 and tried heat and everything, i was told to just undo them and they should be fine, well there are not fine the caps are twised :eek: so you have idea of how tight they were griping.
I had to pull the bolts out from the caps with a hydralic puller, they were stuck solid, i don't know how i undid them in the first place :chairshot
Is this common problem?
I had to really go at them to remove the caps, and its damaged the caps only, can these be replaced? i've been told that that i can't and the engine is scrap :eek:
how do i go about replacing them, there is 4 caps on the inlet cam thats gone :P
I'm so hoping that the head is not scrap.
do i need to have them bored to fit to my head?? can new caps be bought from nissan?
Any help appreciated
https://www.sau.com.au/forums/topic/76178-cam-shaft-caps-help/
The caps are machined (line-bored) as part of manufacture of the head and the bad news is they aren't available separately as spare part. If they're twisted as bad as you say then I'm afraid your up for another head.
The reason the bolts stick is that crap (mainly carbonised oil residue) build up between the shank of the bolt and the inside of the cap. When you try to undo the bolt the crap basically jams the bolt solid in the cap.
Could i not get some caps off another engine and get them line bored too the rest of them?
Yes that's possible...if you were a bit closer I have a head there you could have for free.
Edit: get some quotes first....you might find the machining will be more expensive than sourcing a secondhand head.
**bangs head up wall** thanx for the kind offer dude :cheers:
Its so hard to get parts for the RB20's over in the uk, totaly sucks.
I'm just glad i didn't send the head of before i made this error, one thing is scraping a head, scraping a ported and polished head is just stupid :)
I may send the head off to Abbey Motorsport (uk) tomorrow and see if they can't do something with it.
If it costs me £500 it would be cheaper then getting a second hand head.
My dead mint head :cheers: R.I.P
Well you might be lucky and they can do something with it. If the worst comes to worst let me know and I can ship you over some spare caps from this other head as replacements (you pay shipping, of course :) ). But you'd still have to have the bores machined/honed to suit.
    • So, this shouldn't be such a mission, but there were a few tricks so I thought I'd post up a DIY for it. This was on a Q50 Red Sport but I doubt any other V37 model is very different (maybe just less steps for the intake heat exchanger hoses) I pulled the radiator out to flush it because the car was running hot at the track, but obviously the same steps apply for changing a radiator for any reason including an upgrade. If you are removing the radiator, you of course need to drain and refill, so have 5+ litres of blue coolant ready. You don't need to drain the intake heat exchanger to remove the radiator but depending on your plans you may need a couple of litres for that as well. You will also need something to deal with the auto transmission lines, I used 2x 8mm rubber caps on the radiator side, and a short length of 8mm pipe on the car side.....unless you can block these lines quickly you will loose AT fluid and it may be enough to hurt the transmission if you don't refill it. Other than that....lets go... "First, jack up your car". Yes really, and put it safely on stands. If you are not confident doing that you need to give this job to a mechanic
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
