Hey guys just fitting the new FMIC which is pretty much the same as a hybrid one. I am using the hybrid intructions *PLEASE SEE ATTACHMENT*. and am just wanting to know what others have done with the carbon canister i am pretty sure that is it as in the photo that hole goes straight through where it is at the moment. I guess i can possibly move it back further but yea any help would be appreciated.
https://www.sau.com.au/forums/topic/76579-quick-fmic-help-please/
the carbon canister is at the front of the engine bay on the right hand side, near the air filter.
Are you sure it isn't the oil filter you are talking about? coz thats about the only thing on the engine side corresponding to the pic you have posted
thanks for the post lazy-bastard um now i am a little lost the oil filter is just on the side of the block isnt it ??? this is a black canister looking thing i will try and get some photos of it but yea basically when you take the front bar off it is on the driver side screwed onto the wall which as shown in the picture needs to be cut out ??? so i am a little lost
hmm after alot of searching and comparing engine bay photos i am 100% sure it is my carbon canister i do have one question though are the put in in japan or only when they come across to australia as my canister defiantly has a made in australia on it so i am guessing it was done at compliance ???
anyways lazy are the 2 photos attached what you are refering to as the carbon canister...
Your thinking that the hole has to be made on the wrong side.
If its Hybrid style the hole needs to be made on the other side underneath the water resivoir.
The canister does not need to be moved nor will it be in the way.
The piping will replace the upper pipe that goes from the intake to return over the radiator fan and curve down underneath the water resivoir.
on the canister side of the intercooler it will meet up with the one origional pipe ramaining.
Yeah Leigh, that is the carbon canister I was referring to.
As Slide said, you are bringing the return pipe up the wrong side of the engine. It comes up the left hand side of the engine bay and crosses over between the fan and the front of the engine.
thanks for the replys guys i understand what you are saying but it looks like either through complaince or some guy over in japan may have relocated it or else i am just retarted i will take some photos of it later today and post it up but see the attached pic which you posted slide i have put a red circle around where the black canister.
The canister is on the passenger side. You are going to make the hole in the drivers side.
Have a look at your own pics.
Enjoy
El Bee
Enjoy
El Bee
ahhhhhhhh i am going crazy i know the hole has to go on the drivers side but the canister is ON THE DRIVERS SIDE ;) thats it i am getting photo's in like 2 hours hehe i will post em up to show you what i mean :confused:
I know what you mean leech hehe Your talking about the big black canistor on the drivers side. (circled in thepic???) Mine has it there as well if that isnt where its supposed to be.. ?
To save your sanity.. slap the intercooler up, if its in the way just move it somewhere else its only got like 1 or 2 bolts holding it on. My intercooler has the intake/return pipes going in the same direction, so it isnt a problem for me.. but it does look like it would get in the way...hmm
Have it relocated to the passenger side where it should be.
Ive seen complianced lines that have them on the radiator support at the front and at the back over the turbo hanging off the strut tower but never on the drivers side because the line comes out near the aircon comp and up the side of the radiator whether it be at the front or back out on the drivers side?
Your cars weird but awaiting pics
justin yea i am saying mine is about where that silver thing is showing in yours maybe a little higher but not much. Anyways got some photo's on the gf's camera but dont have the software at my place i will get her to email them to me tomorrow morning and should have them up by 11ish hopefully :)
its the canister, some are biggger even 3 times the size of most.
Ide move it to the corner at the back right hand side (some have abs here)
All of the bigger ones ive seen were mounted near the turbo but away from the heat ill post pics when i can take one
cheers slide yea i was going to fit the piping then basically work out if their is enough room to just slide it back a bit further i guess i will know later on. :D
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
