An excellent, mildly modified R32 GTR for Sale
1989 model in Gunmetal Grey
Recently imported and fully complied
Modifications fitted here in Australia
88,000 kms
Apexi Power FC Computer and Hand Controller
Apexi GT-Spec Intercooler and hard pipe kit
Apexi 80mm Super Suction Air Pod Kit
80mm Z32 Air Flow Meters
Tomei Adjustable Cam Gears
3.5" exhaust
3" Hi Flow Cat
N1 Water Pump
Alloy radiator with electric thermo fan
Trust High Pressure Radiator Cap
HKS Electronic Fan Controller
Greddy Alloy Radiator Pipe
Greddy Alloy Pulleys
Nismo Timing Belt (just changed)
Trust Oil Cooler Kit with Remote Filter
Cusco Front Strut Brace
Cusco Rear Strut Brace with Floor Brace
Cusco Brake Cylinder Stopper
Nismo Oil Catch Tank (with sump return)
ARC Titanium Radiator Deflection Plate
BRAND NEW Xtreme Clutch
Nismo upgraded Clutch Slave Cylinder
Stainless Steel Clutch Cable
Stainless Steel Braided Brake Lines (ADR Legal)
Veilside Side Skirts
Sard Rising Rate Fuel Pressure Regulator with Pressure Gauge
Nismo Oil Cap
Nismo Fuel Cap
Nismo 260kmh Speedo
Section Sports Engine Torque Damper
Splitfire Coil Packs
Iridum Spark Plugs
Pivot Shift Light (small version)
Pioneer deck with 12 stacker in boot
Momo Steering Wheel
New Leather Gearstick and Handbrake Boots
Earth Grounding Kit
Full set of workshop manuals and documentation
Currently registered
Recently dyno tuned by Tilbrooks.
All new oils and fluids throughout the car, new brake pads and piston seals, bushes, belts, battery etc.
New Federal Tyres on original wheels.
Second set of spare tyres.
Brant Car Alarm with triple immobilisation and battery backup
Fully complied and registered.
ONLY $28,990 ono
Contact Matt
Adelaide, South Australia
0419 853393
https://www.sau.com.au/forums/topic/77180-r32-gtr-for-sale-in-adelaide/
I have a Black 1989 GTR. The car is very origonal with out huge mods. Not as hammered as the modified ones. Sparko Wheels. New exhaust from turbos back. 300km dash. Mint interior. Want around $28000. May trade R33.I can be contacted on 0418817836.
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
