Sat Night Cruise (WARNING DIAL UPers)
  • Replies 80
Originally posted by tactic
our pics turned up pretty good ed!
considering we had no light
mine are uploading now!
yup...sucks how they turned it off :)
oh well...
hurry up and upload :O
EDIT: alot more to come but I CBF doing them....sleep then up for the dawn run :uh-huh: :mad: Pics from the dawn run tomorrow I guess :P
good stuff
i will have a Canon Powershot S45 very shortly with a 512mb CF card and a 32CF card..... mmmmmm hundreds of 4 megapixel pictures.....
Oh and a tripod.... and i bought this thing today, it's like for taking those low down shots.. it bolts to the camera likea tripod only its a tiny little swivel thing which keeps teh camera off the ground by about 1-2cm.... its wicked :mad: now i can take angled ground shots with time exposure and they'll come out perfect:D
Email -all- your pics from tonight to [email protected] and i will add them to http://skylines.pnc.com.au
Sadly my pics didnt turn out at all, dunno if it was the settings of my CyberShot or just me not knowing how to use it properly ... i think i'll stick to daytime photo's.
Awesome night guys was fantastic to actually meet the people behind the nicknames. Everyone was -really- friendly which i totally didn't expect. Would be great do it all again afew times throughout the holidays.
do you want just web quality? b'cos each full res shot is about 1.5mb :mad:
How friendly was Minh and that security guard eh? *shivers* :shake: :shake: :shake: :bahaha: :burnout:
Originally posted by BY BY
Your in trouble now yang...:Bang:
Ed: that invisible touch looks awesome - good work
I got big size of that so if you wanna get it developed at a kodak shop etc in A4/A3 size let me know :D
XCUZME: nah didn't open the open halfway through the shot at all :( Happy b'day dude! Hit the magical insurance 25?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
