  • Replies 78
Put 'em away boys, you're acting like you've never seen a chick before.
There just being nice, if they were hanging out the boys would be asking: you single, can you show us some photos (car) even unpainted.
But maybe they are a bit over bearing, well any ways there a good bunch of coconuts the guys on here i am refering to. There is plenty of meetups as well so there is always something to do.
ANY new liner, boy or girl, is worth saying hello to. That's what makes this such a fab community.  :uh-huh:
Yeah i know, i'm just being a prick as usual.
hey newbie
I'M NEW TOO. i WANT TO KNOW HOW TO USE THIS SITE PROPERLY. i HAVE A R33 GOING ON 3 WEEKS NOW AND WANT TO FIND A SKYLINE CLUB THAT AREN'T TOO YOUNG FOR WEEKEND DRIVES THAT HEAD SOMEWHERE NEW FOR A BARBIE OR SOMETHING. WE ARE IN OUR EARLY 40'S AND ENJOY THE A DAY OUT IN THE CAR.
CAN ANYONE HELP OUT THERE. WE ARE FROM THE BRISBANE AREA.
E-MAIL ME.... THANKS.
wtf are you serious...
first off why do you feel the need to use caps...
second you have posted in the canberra area check a few places above u will see a brisbane area.
third... i got nothing but god damn got randomnes
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
