My HICAS light keeps coming on after about 15 minutes of normal, straight highway driving.
I had the rear HICAS bar replaced as it was bent, but the light still appears. The steering feels ok, but is a little notchy when you turn the wheel either way.
Im going to take it to Wilkinsons the next time Im in Perth, but in the meantime, anyone got an idea what it may be, or experienced similar?
https://www.sau.com.au/forums/topic/77405-hicas-light/
Dude the light comes on when the power steering fluid becomes low as well.......
Check that before spending any money man
Mike
https://www.sau.com.au/forums/topic/77405-hicas-light/#findComment-1415930
seen the same when a boss kit wasnt fitted properly - I know your case is different, but you did ask :)
Lock your hicas, the car will handle better, you get the added bonus of weight reduction and you can just remove the light bulb from the days. I did this, much better to drive, never looked back.
https://www.sau.com.au/forums/topic/77405-hicas-light/#findComment-1417343
rossco,
One of the joys (not) of an 89 GT-R is the randomness of warning lights. Check your power steering fluid levels (top it right up anyway). Also when the warning light comes on, go and have a look at the module in the boot. With the engine on there should be a flashing light. It will flash anything up to twenty something times & then briefly pause. Count the number of flashes & compare with the diagnostics in the manual. I will try & dig the page out if you don't have it. Usually turning the car off/on again makes the light go away.
https://www.sau.com.au/forums/topic/77405-hicas-light/#findComment-1418437
I have this problem too. Mine only comes on when im driving on the highway. From what i have been told it can b anything from the non standard steering wheel or HICAS capable boss kit to air bubbles in the hoses. I dont know if the air bubbles in the hoses is true but thats what i was told. I know a few people who have skylines and their lights come on too. Mine has no change in driving when the light comes on so im not gonna stress about it.
Jackie
https://www.sau.com.au/forums/topic/77405-hicas-light/#findComment-1418998
  • 9 months later...
Mine has started to play up again :O, it was ok for a while after instlling spacers but now the light is back on again.
jaygtr, they run hydrolically and can only be stopped with a HICAS lock kit or HICAS removal bar.
If i fit the lock kit will it stop the knocking coming from the hicas motor?
https://www.sau.com.au/forums/topic/77405-hicas-light/#findComment-2085357
  • 7 months later...
After-market steering wheels can also cause hicas issues. The stock steering wheel holds the steering sensor in proper place. I've heard that there are boss kits that cater for hicas (someone please confirm this, i'm looking for it as well). If the sensor is off alignment, it tries to calibrate for roughly 10 mins and when it cant it gives up and fires the warning lamp.
When you start to get notchy feedback and all of that, bar that baby up. not worth the dollars to troubleshoot.
https://www.sau.com.au/forums/topic/77405-hicas-light/#findComment-2725785
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
