Hey ppl..
Quick question - are turbo timers legal in NSW. If i'm getting a car registered for the first time will it be an issue.
From what I had heard, it's illegal to leave your car when it is running, which is what happens when you use a turbo timer.
Forgive my ignorance :rofl:..
I fairly sure it IS illegal to leave your car while running - but I also had problems getting insurance for my R32 GTR if it had a timer.
I needed a 3 point immobiliser that auto armed with 30 seconds - otherwise no insurance
HtH
https://www.sau.com.au/forums/topic/77677-turbo-timers/#findComment-1419622
yeah, wouldn't mind finding out if this is legal in Victoria also. I have heard it is illegal to have a car running unatennded. Could it have anything to do with the saftey aspect as well? Eg. if you have a accident where its bad, and then turbo timer may keep the engine running and fuel pumping then it might not be too pretty.
https://www.sau.com.au/forums/topic/77677-turbo-timers/#findComment-1419869
Ok, I contacted the RTA.
Here is the response from them
Anthony,
Turbo timers are illegal in NSW.
There are a number of reasons.
1: Where a vehicle was built to meet the Australian Design Rules, from 1972, it is a defect if the key can be removed from the ignition switch while the engine is still running.
2: Under NSW law, it is an offence to leave the engine running on an unattended vehicle.
If you have any other enquiries, don't hesitate to reply or contact Technical Enquiries on 1300 137 302.
Regards
Colin Lambert
Technical Enquiries Officer
Just thought everyone might be ineterested.
https://www.sau.com.au/forums/topic/77677-turbo-timers/#findComment-1420631
oh ok,
well i know it kinda defeats the purpose.. but i have to wait for my turbo timer to count down before i leave the car anyway - cant arm the alarm while the engine's still running..
Its not much of a hassle to leave the car runnin for an extra minute before u leave it.. unless ur in a rush.
https://www.sau.com.au/forums/topic/77677-turbo-timers/#findComment-1420662
As has already been noted in this thread, there are three main reasons why turbo timers are a bad idea:
1) They are illegal as your vehicle remains running with the key removed and unattended.
2) They keep the fuel pump primed after an accident. Personally I would prefer not to burn to death.
3) They provide thieves with a very good indicator of which wires to go for. They also often have problems with alarms.
Spend you money on something else that actually improves performance or comfort. If your worried about your turbos, either don't boost the whole way home or go for a slow drive around the block before parking. Personally I just try a drive off-boost for the last couple of minutes of my journey (which, given I live in inner-western Sydney with lots of pedestrians/traffic, is a good idea anyway).
LW.
https://www.sau.com.au/forums/topic/77677-turbo-timers/#findComment-1420690
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
