Looks can be deceiving. It's supposed to be 20% less throw length, not shorter in length. But I believe it is slightly shorter.
U want a shortend shifter. Take an angle grinder to yours then weld it back together. U want to be able to shift quicker, buy one of these babies.
Ok, sorry for the confusion guys. It looks like this shifter is only for R33 GTST Boxes. So my appologies to all the guys with R32's that PM'ed me.
If your keen to get a hold of one thou. This is where mine came from http://www.justsr.com/forum/viewtopic.php?t=85
Tell greg your from SAU and should pass on a discount, as a group buy was done a while back and he surely made some cash from us.
I have been telling people that I will ship it for $10. So i'll make that open to everyone. Dont PM me asking for a reduction in price! This is a bargain IMO and i'm already loosing money on a new item. Thanks.
It did fit into the box and it did shift gears. However the throw length was not decreased and the bush on the end of the shifter would not stay on for some reason.
Also the shifter itself felt longer in length. I was told by Greg @ JustSR that at the time of this group buy there were not manufacturing short shifter to suit the RB26 Box. However they do have some 'new designs' now.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
