  • Replies 114
Show starts at 10am, so I say we meet up around 9:30am at the Twin Shells.
If anyone is meeting us at the Twin Caltex's we'll need to know so we don't just shoot past.
If they're not, maybe we should take the scenic route via the Pacific Highway?
Guest DIRTgarage
Is there an earlier cruise for guys that are entering...we have three cars...DIRTgarage, voona and Sticky Dave...we would like to get there about 9....any takers??
Hey DIRTgarage
we are leaving the twin shells at wallsend at 7:50 sharp, and picking gruntn up from the south bound caltex on the freeway. so we should be getting there before 9am.
if all us who are entering arrive at the same time we will get a spot together :P
just go to the other thread an let gruntn know you are a definate :D
Paul, you know that entrants need to be arriving at 8am dont you
Guest DIRTgarage
I thought it was cars arriving at 8am ...open at 10am. So was thinking that i had a 2hr window to arrive. Is this not correct?
STOP PRESS>>>>. just checked the entry form and section 4 states....show cars arrive at 8-9.30.
sweet!!
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
